Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current Classic GM Trucks Classifieds > The 1960-1966 Chevrolet & GMC Pickups Parts Board
Old 04-07-2013, 05:54 PM   #1
LT1 Burb
LT1 Burb's Avatar
Power brake booster
Anyone here interested in this brake booster, came out of a truck I parted so don't know if it works or not, 75 shipped.
LT1 Burb is offline   Reply With Quote
Old 04-07-2013, 06:46 PM   #2
oem4me
oem4me's Avatar
Re: Power brake booster
I'm interested in acquiring all associated parts to install power brakes in a non-PB truck. Brackets, booster, manifold fittings, etc. Basically anything I would need. I'll refinish/rebuild, so I just want the complete factory correct parts set-up. Do you have that?
Old 04-07-2013, 06:57 PM   #3
gimmy 64
not to hi jack lt1 but i do of he doesn't. took off my 64 gmc.
gimmy 64 is offline   Reply With Quote
Old 04-07-2013, 07:33 PM   #4
LT1 Burb
LT1 Burb's Avatar
I think all you need is this and the fitting which goes into the manifold, I don't know if I have one but will look later.
Old 04-08-2013, 02:17 AM   #5
oem4me
oem4me's Avatar
Still interested, but did a little checking and I'm thinking that booster may not be the right config for my '66. ?
Old 04-08-2013, 09:15 AM   #6
LT1 Burb
LT1 Burb's Avatar
The firewall mounting is right for 60-66 , this maybe a gmc booster . I really don't know anything about it but it will bolt upto 66.
Old 04-08-2013, 10:14 AM   #7
60-66
60-66's Avatar
From what I see that booster is a 1963 only. There will be a mounting plate that is steel instead of the later aluminum wedge that angled the booster to the drivers side. This one aims straight out from the firewall. The booster itself is also different and near as I can tell is one year only,. I have one of these in the accessory box NFS but can use for reference.
https://67-72chevytrucks.com/vboard/...1966+gmc+panel
IS IT an EATON or Chevrolet rear axle https://67-72chevytrucks.com/vboard/...d.php?t=843778
The hubcap thread http://67-72chevytrucks.com/vboard/s...d.php?t=702839
WANTED : 1963-1966 6 Cylinder Fan Shroud
WANTED :1964-1966 PANEL TRUCK
60-66 is offline   Reply With Quote
Old 04-08-2013, 01:13 PM   #8
oem4me
oem4me's Avatar
Sending you a PM Jon.
Old 04-09-2013, 10:44 PM   #9
oem4me
oem4me's Avatar
Sorry LT1, I'm going to pass on the booster. Sounds like an opportunity for the '63 owners out there though. One year only parts are hard to find!
Old 04-13-2013, 06:35 PM   #10
michael bustamante
michael bustamante's Avatar
don't mean to hijack but I saw one of these in a k-20 and it did have an adaptor plate, I did pull the rod that goes to the pedal assy if your buyer needs it.
1967custom
michael bustamante is offline   Reply With Quote
Old 04-13-2013, 11:54 PM   #11
sigshooter
sigshooter's Avatar
I can send you pics of everything you need to add power to a non power brake truck. I have several of these setups laying around and just recently added one to my truck
1965 long bed ( grandpas old truck )
1964 long bed BBW Custom Cab
1966 Short stepside
1964 long bed
1965 long bed Custom Cab, factory air, V-8, powerglide
sigshooter is offline   Reply With Quote
