Old 04-05-2013, 04:52 PM   #1
forestb
forestb's Avatar
350 trans stock column
I have a 350 trans and a stock shift on the tree steering column for an automatic transmission that is not hooked up. How well will this work if I connect them sense the original trans had one less gear? Will I be able to tell if it is in the right gear?
forestb is offline   Reply With Quote
Old 04-08-2013, 04:36 PM   #2
forestb
forestb's Avatar
Re: 350 trans stock column
Com on. I know some body out there has an answer for me.
Old 04-08-2013, 04:46 PM   #3
1963c-10
1963c-10's Avatar
Original auto trans would have been a 2 speed powerglide. Im a manual trans man myself, but Im sure the auto trans guys will chime in. I know that there are several aftermarket coumns available, but sounds like you want to retain the stock column?
1964 Short bed trailer
Old 04-08-2013, 05:22 PM   #4
Rich 5150 69
Rich 5150 69's Avatar
People here in he past said it works fine in the drive position, but I don`t know whether you can grab the L-1 / L-2 position....
`64 C10 vortec 350/350/373 posi
`69 RS/SS 350/350/308
`37 Ford 406/350/324 traclock
`68 Dart 370/904/323 suregrip
Rich 5150 69 is offline   Reply With Quote
Old 04-09-2013, 08:00 AM   #5
sigshooter
sigshooter's Avatar
It will work fine, you can get all three gears just when you go to 1rst it won't show on the indicator. All other gears display correctly
1965 long bed ( grandpas old truck )
1964 long bed BBW Custom Cab
1966 Short stepside
1964 long bed
1965 long bed Custom Cab, factory air, V-8, powerglide
sigshooter is offline   Reply With Quote
Old 04-09-2013, 08:45 AM   #6
kieth
kieth's Avatar
I have a 700r4 with a 91 tilt wheel, no indicator at all and I do not have any trouble telling which gear the truck is in.......Kieth
kieth is offline   Reply With Quote
