Old 04-08-2013, 03:47 PM   #1
looney
Rebuilt motor not firing
Any ideas would be helpful. Rebuilt 350, set it on frame, new plugs,wires,distributor,points etc. I get 12v out of coil wire but nothing out of the plug wires so voltage seems to be getting to the points, not sure where to check now.
looney is offline   Reply With Quote
Old 04-08-2013, 03:53 PM   #2
Tinkermc
Re: Rebuilt motor not firing
spark, fire gas is all u need but spark is very important at spark plug
Tinkermc is offline   Reply With Quote
Old 04-08-2013, 03:54 PM   #3
Longhorn 70
Longhorn 70's Avatar
do you get spark out of the coil when ground side is connected then disconnected?
1970 Longhorn, Front Disc, 350/4 bolt, 882 heads, HEI, Edelbrock, 700R4, HO-52/4.11.
1996 Corvette, Collector Roadster, LT4, 396, 450RWHP, 6sp, 4.11/Dana44/posi 5 point roll bar
And let us not grow weary of doing good, for in due season we will reap, if we do not give up. Gal 6:9
Longhorn 70 is offline   Reply With Quote
Old 04-08-2013, 04:53 PM   #4
cdowns
cdowns's Avatar
have you set the point gap and dwell?
Old 04-08-2013, 05:14 PM   #5
truckster
truckster's Avatar
First place to check is to make sure the points are opening. If I remember correctly (it's been a long time) the points gap should be about .019 when the top of the lobe is in contact.
That should get you in the ballpark.
truckster is offline   Reply With Quote
Old 04-08-2013, 09:51 PM   #6
PanelDeland
I am a Referee of life.
PanelDeland's Avatar
Check the rotor.I've forgotten it and had a day or 2 looking for a problem that I created.
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion.
You can't fix stupid,not even with duct tape.
"My appearance is due to the fact that "GOD" does punish you for having too much fun!"
Barrett-Jackson has perfected alchemy,they make rust into gold!
"You can lead a horse to water but you can't saddle a duck"
"Cleverly disguised as a 'Responsible Adult'
"Sometimes your Knight in shining armor is just a retard in tinfoil"
PanelDeland is offline   Reply With Quote
Old 04-09-2013, 05:48 AM   #7
luvbowties
luvbowties's Avatar
Exclamation Re: Rebuilt motor not firing
Since you have points, you got a condensor too. I used to tune-up cars for a business, and ran into 3 bad condensors in all the cars I experienced. One of them was a used one. The other TWO were NEW ones! Don't overlook it! Seems like today's uni-points--points and condensor mtd. together--seem to give more problems re: quality control than they used to when individual components!
Sam
luvbowties is offline   Reply With Quote
