Old 11-16-2003, 08:09 PM   #1
1971 2wd
Question 6" or 8" lIft kits for 1972 Blazer
What is the tallest tries you can run with a 6" and 8" lift kit???
I'm planning to run 36" tall tires and someday move up to 38"..
It still's need's to have pleanty of room for flexing..
1972 Blazer
Thank's for an info......
1971 2wd is offline   Reply With Quote
Old 11-16-2003, 09:02 PM   #2
6772king
6772king's Avatar
I have a 8" with 2" traction and a 3" body on my swb with 42's ,,,,,, on my blazer I had 35's and a 4" lift and they would rub when I flexed it hard I would go with the 8 if you plan on running 38's
67 chevy short step 2wd 427
71 chevy short fleet 4x4 396
72 gmc jimmy 2wd 377
71 chevy blazer 4x4 454
69 chevy longhorn 5.9l cummins
72 chevy 400 2wd custom camper
67 chevy lwb 4x4 454-in pieces
67 chevy panel soon 4x4-400
67 gmc dump 4x4 1 ton-305 WTF!!
72 chevy 3/4 ton 4x4 burb 350
70 chevy panel 2wd 302 5 speed tko
"THERE IS NO REPLACMENT FOR DISPLACMENT"!!!!!!!
6772king is offline   Reply With Quote
Old 11-16-2003, 09:02 PM   #3
6772king
6772king's Avatar
#2
Old 11-16-2003, 09:05 PM   #4
6772king
6772king's Avatar
here is my blazer with the 4" lift and 35's
Old 11-17-2003, 01:14 AM   #5
bigbluthng
bigbluthng's Avatar
here's mine with a 3" body lift and a 4" suspension lift for 7" with 31's
bigbluthng is offline   Reply With Quote
Old 11-17-2003, 01:28 AM   #6
2wdBlazer
The Blazer King
2wdBlazer's Avatar
I have 9 inches on 38x15.50's. They will rub on hard flexing. Needs another inch or 2.
72 2wd Blazer. Its the superbichinest, megacoolinest, superflowinest.
2wdBlazer is offline   Reply With Quote
Old 11-17-2003, 02:14 PM   #7
bouncytruck
SKINNY TIRES RULE!
bouncytruck's Avatar
There is a guy near me who has 39.5's on what he says is a 6" lift. He says that the suspension is so stiff the only travel is in the tires. I think he has some trimming but there is still only like 1" of clearance. I don't know if it rubs. It is for sale too - and has been since the beginning of the summer (starting price was $6500, then it went to $4500, now it is back at $8500! Personally, I think it is worth around $2500)
http://adcache.collectorcartraderonl...0/59735800.htm
bouncytruck 1972 K5
The Hauler 1994 K1500 Suburban
The Daily2010 Kia Soul
Wife's Ride2014 Fiat 500L
bouncytruck is offline   Reply With Quote
Old 11-17-2003, 06:27 PM   #8
Bluegoose972
I'm getting ready to run 36"x14.5" Truxxs Tires with a 6" suspension lift on my blazer. It might be a little tight and I will let you know how it works out. But the tire width and offset will make a huge difference on what hits/fits. Stick with a narrower 36"x12.5" tire and 4 5/8" backspacing and you should fit fine with 6" of lift.
In my opinion, I would install a 6" suspension lift for now. You may have a little trimming and/or rubbing, but I don't see it as that bad. Then when you want to upgrade, add an additional 3" body lift to get the extra clearance you need for the 38" tires. Stay with a 10" rim and the 4 5/8" offset (check the tire to spring clearance inside) and you should be good to go!
Bluegoose972 is offline   Reply With Quote
Old 11-17-2003, 07:09 PM   #9
LeRoy
Registered truck nut
LeRoy's Avatar
This is my K5 with seven inches of total lift and 36x14.50x16.50 Swampers. They fit nice and only needed a bit of trimming on the front edge of the rear wheelwell. It's now in the process of a 9" lift with 38x15.50x16 swampers
MOUNT VERNON, WASH. STATE
Need a part? Just PM me
LeRoy is offline   Reply With Quote
Old 11-17-2003, 07:10 PM   #10
LeRoy
LeRoy's Avatar
2
Old 11-17-2003, 07:42 PM   #11
bouncytruck
SKINNY TIRES RULE!
I dig your rig LeRoy! Can't wait to see it with the big meats! I like your trailer too. I want to make one that matches my truck - but first I've gotta get my truck running.
bouncytruck 1972 K5
Old 11-17-2003, 09:28 PM   #12
LeRoy
LeRoy's Avatar
Thanks, ya should have been at the meeting and seen K5krazie's K5. Sweet offroader
Old 11-18-2003, 01:50 PM   #13
bouncytruck
SKINNY TIRES RULE!
LeRoy, Aaron lives about 5 blocks from me. He's got a lot of nice rigs. I you guys on the freeway as you were heading to the meeting (saw Dennis' flatbed) but I had a meeting to go to at 11 so I couldn't make it.
bouncytruck 1972 K5
Old 11-19-2003, 11:22 PM   #14
1971 2wd
Thanks for all the info!!!
Dose anyone have a 8" for sale???
