Old 04-09-2013, 10:55 AM   #6
Desert1957
Desert1957's Avatar
Re: late dually wheels to 83 1 tonner ?
Be aware of some other wheel info, the center hub bore diameter is larger on new style wheels causing wheels to run off center. You can fix it by using a "Hub Ring" or just checking the wheels before you purchase them.
Here is some helpful info...
76-2000 Hub Bore is 4.56 / wheels are 8 X 6.0
01-2007 Hub Bore is 4.60 / wheels are 8 X 6.5
Desert
Desert1957 is offline   Reply With Quote
