![]() Join Date: Sep 2011
Clr
What are the steps for using CLR on the rust? Use it full strength or dilute it? Which Scotch Brite pads?
My 66 is a great candidate for this from what I've seen on here. Posted via Mobile Device
Past Master Triluminar Lodge #117 GL of WVa My 1963 4x4 Suburban build; http://67-72chevytrucks.com/vboard/s...d.php?t=531274 My Gallery, now with pics of my 1966 C30 motorhome. http://67-72chevytrucks.com/gallery/...&ppuser=103447 |
Re: Clr
Hey mike I just did this with great results. I used 3 parts CLR to 1 part warm water and green scotchbrite pad and just hit the spots that I wanted to do, once you get started you'll see what you need/ or how much you want to do! Here is a couple pics
![]() ![]() ![]() ![]() Posted via Mobile Device
Justin |
Re: Clr
The shine it has in the pics is because it's still wet too btw
Justin |
Re: Clr
Thanks Justin!
