Old 02-08-2013, 01:28 PM   #1626
hgs_notes
GEARHEAD
hgs_notes's Avatar
Re: '66 Sunbeam Minx Project - F20C/6sp/4-link/Discs...
Sorcery!
hgs_notes is offline   Reply With Quote
Old 02-08-2013, 01:32 PM   #1627
Jonboy
Slots go on anything!
With a name like "picklex" I would have thought you would put cucumbers in it....
While the 'beam is on the rotissifier, you may look into doing a spray on bedliner or such to the underside. We did that on a Monte Carlo we took off the frame, worked like buttah!
Jonboy is offline   Reply With Quote
Old 02-08-2013, 05:55 PM   #1628
watahyahknow
watahyahknow's Avatar
its not the stuff i was talking about , i am however wondering wat would happen if you leave some metal submerged in the stuff (like inside some boxsection ) , it looks like its some sort of acid that could keep eating away at the metal
i got a job again and having fun at it too
idea's for the trucks and the order of things to do are taking shape and get closer to being realized , a few more months and i be able to start building for real
i complete 2 of the trucks intoo running fashion one custom and one basicly stock the thirth will be sacrificed for parts
watahyahknow is offline   Reply With Quote
Old 02-08-2013, 06:20 PM   #1629
Looks interesting. Need to do some more checking into it.
Rust is definitely an issue on anything lying around down here very long.
Old 02-08-2013, 07:11 PM   #1630
theastronaut
theastronaut's Avatar
You may have said and I forgot or overlooked it- are you going to strip the car to bare metal?
theastronaut is offline   Reply With Quote
Old 02-08-2013, 07:39 PM   #1631
Frizzle Fry
Frizzle Fry's Avatar
Originally Posted by hgs_notes View Post
Sorcery!
Check out the second pic in this post
Nope, it can be left on there (simply wiped off) and just scuffed up to apply epoxy primer right over it. Read up.
You can even find it mentioned with positive result elsewhere on this site. I'll let you guys know what I think of it shortly.
Not fully bare, just down to a good base. Whatever has been holding on this long and doesn't knock off with some sanding will be a fine base for epoxy and 2k.
Frizzle Fry is offline   Reply With Quote
Old 02-11-2013, 03:09 AM   #1632
Frizzle Fry
Well, no pics but so far so good with the Picklex. It does remove surface/flash rust very well. Not sure about the long term protection and all the other claims yet. Time will tell...
Old 03-27-2013, 01:06 AM   #1633
ksucatz
Suppose to be workin........
ksucatz's Avatar
I just saw this today and thought of the Beam
http://www.speedhunters.com/2013/03/...-fitted-to-it/
Next project.....Stupid big turbo?
Brent
'68 C10
'70 C10
'72 LeMans
"03 Trailblazer
"Stupidity is like a skill, some are born with it and some develop it over a period of time."" Author unknown
ksucatz is offline   Reply With Quote
Old 03-30-2013, 10:32 PM   #1634
LooseCannon
Question on the rotisserie, do you think it could be adjusted down to work with a C10 cab? Thx
LooseCannon is offline   Reply With Quote
Old 03-30-2013, 10:53 PM   #1635
watahyahknow
i seen sumtin else that worked well on truckcabs two big L shaped pieces made from box steel that bolted intoo the chassismount holes
you put it on the floor and just push it over to work on the bottom , its a whole lot cheaper and simpler to make than a rotissery
this might work too
Old 03-30-2013, 11:52 PM   #1636
Frizzle Fry
Hey guys. I'm just finishing up about two months straight of working 6days/wk 12+hrs/day (had 14 in a row in there somewhere). 2.5 weeks off coming up! Driftbeam will be getting some serious love soon!!!
That thing is so badass! No turbo for mine. SC if anything (no messing with exhaust).
It can! the center span is fully adjustable. It's so nice to flip the body over with no effort and set it at any angle you want
Cheap is good. It all depends on your wants/needs.
Old 04-11-2013, 02:14 AM   #1637
nuke1
nuke1's Avatar
WTF!!!! I disappear for a wee bit from the forum and come back to this!!!! a shell of a car, I jsut can not believe it, just can't let good things be can ya, have to go and tear it apart and start to beautify it now, well...... AWESOME!!!!!! can not wait to see a shiney car now.
James
1968 GMC "HAVOC"
1986 GMC "Frank"
J.J.R.H. Design & Consulting
My 68`Rebuild "HAVOC": http://67-72chevytrucks.com/vboard/s...d.php?t=316300
A 58' chev build thread: http://www.67-72chevytrucks.com/vboa...d.php?t=311238
1969 Camaro Pro Touring http://67-72chevytrucks.com/vboard/s...61#post3513361
Swiss Cheese: http://67-72chevytrucks.com/vboard/s...d.php?t=384390
Adjustable Trailing Arm How-To: http://67-72chevytrucks.com/vboard/s...d.php?t=321100
1968 Ford Farm Truck: http://67-72chevytrucks.com/vboard/s...=1#post6555587
nuke1 is offline   Reply With Quote
Old 04-11-2013, 04:32 AM   #1638
Frizzle Fry
Good timing Nuke I've had very little shop time for the last couple months due to crazy work hours (6x12+) weeks plus travel. But I am now off for two weeks
The goal is to have the car to the paint booth before I go back!
Here's a little sneak peek of what I've been up to:
Old 04-11-2013, 08:19 AM   #1639
mcbassin
Still Learning
mcbassin's Avatar
Very clean seam sealer. I may have to steal that trick myself. Nice work.
Old 04-11-2013, 03:26 PM   #1640
Frizzle Fry
I can't take credit for that one. Works well.
Old 04-11-2013, 03:58 PM   #1641
panelrodder81
Doin' it live!
panelrodder81's Avatar
I saw that trick on one of the Powerblock shows a few years back. Highly recommend it!
LOVE this build btw. You do amazing work that makes me cry as I realize how truly poor everything I do is!
-Panelrodder
-Panelrodder
1953 GMC Panel truck - 'Curly'
1961 Chevy Suburban - 'Larry' - Sold
2005 Harley Sportster - 'Shemp'
panelrodder81 is offline   Reply With Quote
Old 04-11-2013, 04:04 PM   #1642
67cheby
67cheby
67cheby's Avatar
nice trick !
67cheby is offline   Reply With Quote
Old 04-11-2013, 06:40 PM   #1643
watahyahknow
they seal bathtubs tiled corners and kitchen aplyances that way too
Old 04-13-2013, 01:45 PM   #1644
Frizzle Fry
-Panelrodder
Yep, I found it on youtube Thanks man. I owe 90% of my automotive knowledge to internet communities
Originally Posted by 67cheby View Post
nice trick !
Whatdoyaknow?
More pics (from a real camera this time).
Finally closed up the gaps in the rear floor exhaust clearancing:
Driver's Side cleaned up:
Prep for Rust Encapsulator application in the hard-to-reach areas:
Weapon of choice (reached deep inside the rockers with this)
Looks thick here, but it levelled out pretty nicely:
...and another shot of the seam sealage (messy looking stuff near the front is actually rust encapsulator:
Old 04-13-2013, 05:31 PM   #1645
71swb4x4
71swb4x4's Avatar
That looks very nice!
Some people are like slinkies, they aren't good for anything, but you can't help but smile when you see one tumble down the stairs.
71swb4x4 is offline   Reply With Quote
Old 04-13-2013, 07:43 PM   #1646
dammitmitchell
the pollock
dammitmitchell's Avatar
what seam sealer is that? i diddnt see it in the above posts.
Jack of ALL trades, Master of none.. (but one... procrastination)
Army vet 02-08
RIP El Jay! Miss you brother!
http://67-72chevytrucks.com/vboard/s...d.php?t=343538
http://67-72chevytrucks.com/vboard/s...d.php?t=386042
dammitmitchell is offline   Reply With Quote
Old 04-13-2013, 08:07 PM   #1647
watahyahknow
by the way if youre tired of ripping youre finger on ragged edges of the metal while smoothing the bead of sealant you could use a round brush with the hairs taped up to about 2/3th of the way it presses the chaulk in further too
Old 04-13-2013, 10:25 PM   #1648
67ChevyRedneck
67ChevyRedneck's Avatar
You're going to need to bring mirrors with you to shows!
Jesse James
1967 C10 SWB Stepside: 350/700R4/3.73
1965 Ford Mustang: 289/T5-5spd/3.25 Trac-Loc
1968 Pontiac Firebird: Project Fire Chicken!
2015 Silverado Double Cab 5.3L Z71
2001 Jeep Wrangler Sport 4.0L 5spd
2020 Chevrolet Equinox Premium 2.0L Turbo
2011 Mustang V6 ~ Wife's ride
American Born, Country by the Grace of God
1967 CST Shop Truck Rebuild!
My 1967 C-10 Build Thread
My Vintage Air A/C Install
Project "On a Dime"
Trying my hand at Home Renovation!
1965 Mustang Modifications!
67ChevyRedneck is offline   Reply With Quote
Old 04-13-2013, 10:29 PM   #1649
watahyahknow
he needs to clearcoat the metalfinish itself , leaving the metalwork and welding visible , i bet there would be a lot of techheads and sheetmetalworkers who would like to see what's done to the car or how he did a perticulair job when he shows the car off
Old 04-14-2013, 02:45 AM   #1650
Frizzle Fry
It's all getting covered with body colored Raptor Liner
Seam Sealer is Fusor 803.
