Old 04-11-2013, 09:01 AM   #1
63burban
Chevy addict
Re: Led lights
Hey guys, I sell the UPD-90651 and have them is stock (two prong and three prong and also the polarity adapters which is needed for GM applications), I have played with them on all sorts of combinations of lights. They work on all combinations including multiple incandescent set ups. The only problem with them is if you have a burned out bulb you can't tell as the flasher will flash anyway. The cool thing about them is that they flash the same speed no matter the load.
I also handle the LED lights for these trucks, park lights, stepside tail and fleetside tail lights.
Three prong flashers are usually for the aftermarket harnesses that you wire yourself.
63burban is offline   Reply With Quote
Old 04-11-2013, 10:26 AM   #2
kieth
kieth's Avatar
Re: Led lights
I do not have experience with LEDs but on the stock stuff we soldered a ground wire to every light housing on my 66 and ran seperate ground wires back to a commom grounding block. No more dim lights........no more chasing bad grounds. Kieth
kieth is offline   Reply With Quote
