Old 04-11-2013, 10:47 AM   #6
BMERDOC
BMERDOC's Avatar
Re: Alignment issue
Most times inner or outer tire wear is associated with toe. Its not hard to assume that tire wear like this is caused by excessive negative camber. As long as the negative camber does not exceed -1.5° tire wear would be a negligible. Have you had a recent alignment. If so, do you have a copy of the results?
Nick Carter
1967 C10 Short bed Fleetside
Project Cheap Thrills!
2WD C10 Modern/Performance Alignments
Easiest Alignment Ever!
BMERDOC is offline   Reply With Quote
a-arm, alignment, shims, spacing, stud
