Old 04-11-2013, 09:53 PM   #1
med.bronze
med.bronze's Avatar
71 vs 72 intake differences
I was out in the garage getting the intake for my 72 ready for a cleaning and noticed two threaded holes on the pass. side that I don't have on either of my 71's. Anyone know what they're for? The first pic is the 71, second is the 72.
1972 Cheyenne Super 10 SWB,bucket seats,dealer cruise,tilt,tac,a/c,shoulder belts, 350/350
1971 K-10 Custom Deluxe
1971 K-10 Custom
med.bronze is offline   Reply With Quote
Old 04-11-2013, 09:55 PM   #2
med.bronze
med.bronze's Avatar
Re: 71 vs 72 intake differences
Here's the second pic of the 72
1971 K-10 Custom
Old 04-11-2013, 09:57 PM   #3
med.bronze
med.bronze's Avatar
I just realized I put pass. side I meant drivers side, oops...
1971 K-10 Custom
Old 04-12-2013, 08:31 AM   #4
JimKshortstep4x4
The holes on the manifold are for mounting an AC compressor. Cars had these holes starting in 69 I believe as my 69 El Camino has the compressor mounted on the driver's side using those holes. The engine in my El Camino is numbers matching with original AC so I am sure that the holes were there on that year.
Truck AC's were moved to the driver's side in 1973 so if your manifold numbers are for a 72 truck then it is probably a late 72.
Jim
1971 Shortbox step side 4x4, 350 sbc, 3:07 rear end
1965 Impala SS 400 sbc, Muncie rock crusher
1966 Impala SS 396 bbc, TH 400
1969 El Camino, 350 sbc, TH 350
1971 Snowplow built on a Blazer frame
1972 GMC Short bed, stepside, TH 400, 427 BBC
Old 04-12-2013, 09:15 AM   #5
med.bronze
med.bronze's Avatar
Thanks Jim, that's interesting. The only other thing I found about my 72 intake was that it shares the same casting number as the base corvettes which I believe mounted their compressors on the pass. side like our trucks and from what I've seen its a 72 year only casting number.
1971 K-10 Custom
Old 04-12-2013, 09:55 AM   #6
turp mcspray
turp mcspray's Avatar
In 72, trucks and corvettes, still used short water pumps, and had a/c compressors mounted on the pass. side. Unlike everything else that went to long pumps in 69. But yes, those are a/c bracket holes.
Turp Mcspray
New life for an old 2wd, farm blazer
http://67-72chevytrucks.com/vboard/s...d.php?t=505987
My Blazer build http://67-72chevytrucks.com/vboard/s...d.php?t=342299
turp mcspray is offline   Reply With Quote
