Rear end width
I've got a '72 C10 1/2T with a 12 bolt non-posi rear end with 3.73 gears. Is there someplace that I can find the exact rear end width dimension from the wheel mounting face on the drum to the opposite wheel mounting face? I need an accurate reference and I haven't been able to find that dimension. Any help?
![]() Join Date: Feb 2004
Re: Rear end width
not sure on mounting face to face. but I can tell you most people measure from backing plate to backing plate. the 70 and earlier rears are like 1/2" narrower. if you call moser they could probably tell you because I ordered my axles from them and they already had the specs!
The Ghost 67 short wide full custom. 550 hp LSX, 4l80E, narrowed 9". Body dropped w/air ride! ........................ ___ .........________//__{\_____ ,,,,,,,/__(⊙)___//___/__(O)_/ @disciple2.rc 💪instagram💪 LED TAILS |
Re: Rear end width
Maybe try a straight edge and a tape measure?
Thats what I would do. Posted via Mobile Device Almost forgot, remove the wheels first.
![]() Join Date: Oct 2008
Re: Rear end width
Jack up the rear, remove wheels, drop a weighted string from each WMS to the floor, mark and measure.
#5 | ||
![]() Join Date: Mar 2011
Re: Rear end width
67 & 68 are 60" 69 & 70 are 62" 71 to 87 are 63.5" 88 to 98 are 65" These are approximate but should help after checking yours....Jim
my build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=459839 Jimbo's long bed step build:http://67-72chevytrucks.com/vboard/s...t=464626<br /> |
Re: Rear end width
Thanks everyone, I'll be pulling everything out and doing the measurements this w'end. Thanks again
