Old 04-12-2013, 12:19 PM   #1
Wellgeo03
Wellgeo03's Avatar
Opinions on running 35s with tbi 454/th400?
Looking at ordering a lift and some new tires for my new crew. I would like to run a set of 35s. It has 3.73 gears with a G80 in the rear.
It currently has the stock size 235s on it and the power is just OK. How badly will the 35s hurt the power?
I am currently torn between a 4" and a 6" lift for it. On my other crew, (86 custom deluxe) I figured a 4" would be fine to run 35s, as I am running 33s on it right now at stock height with no problems. This new crew (90 sliverado) sits almost exactly 1 inch lower than my 86 both front and rear even though both have the same GVW rating and spring count. The 86 is a 350/sm465, the 90 is the 454/th400.
What would you recommend?
Wellgeo03 is offline   Reply With Quote
Old 04-12-2013, 08:25 PM   #2
Wellgeo03
Wellgeo03's Avatar
Re: Opinions on running 35s with tbi 454/th400?
Has anyone run 35's with 3.73 gears and a 454?
Where is the peak torque of the TBI 454s?
Old 04-13-2013, 12:02 AM   #3
dieseldawg142
dieseldawg142's Avatar
you would think a 454 should have no problems with 3:73's & 35's. my blazer had a 400sb, 3:73's, & 35's. was'ent a speed demon, but was'ent no slouch either. my crew (also 454,T400) has 38.5's with 4:56's, great off the line, but horrible on the freeway. i would stay with the 3:73's, if it drops your powerband too much, try 4:10's. would'nt go lower than that with the T400, kiss away any fuel mileage you think your getting!
dieseldawg142 is offline   Reply With Quote
Old 04-13-2013, 01:12 AM   #4
Rubble
You should be fine with 35s & the 454.My 86 has 35s with a mild 350,465 & 4:10s Really good combo.Good off the line & not too bad for highway cruising...2500 rpm @ 100kms.
1977 Chev C30 454/465/14ff DRW
1974 Chev C20.350/465/14ff
" Rock n Roll ain't noise pollution"
Rubble is offline   Reply With Quote
Old 04-13-2013, 09:02 AM   #5
b454rat
I ran a 454/400 with 40' boggers with 3.73s, and could still lite the tires up going around a corner....IMO it's a good compromise, what I love bout big blocks, lotsa torque!!!!!
2000 GMC CCSB 454/4L80 6” lift SAS
1999 Chevy CCSB 454/NV4500 4” SAS
1999 GMC Yukon 350/4L60 6" SAS
Old 04-13-2013, 02:29 PM   #6
Redcap
I'm running 35x12.5s on my K20 and 4.10 gears, which are a little too low for my 454 right now (I could pull a house down), but will be perfect once the Ranger OD goes in.
'77 K35 - 454, SM465/NP205, 4.56 D60/14bFF
Redcap is offline   Reply With Quote
Old 04-14-2013, 11:57 AM   #7
Joesjunk
Joesjunk's Avatar
I have a stock original 454/400 with 3:73 gears and 35's and it runs perfect.
72 3/4t Custom Deluxe 402/auto 66k Original paint
71 3/4t 4x4 Custom Deluxe 10k original miles Original paint
71 3/4t Cheyenne 402 70k original paint
72 3/4t 4x4 Custom deluxe
72 3/4t 4x4 Custom deluxe 91k original paint
72 Cheyenne/30 Dually
69 Camaro SS396 4-speed
13 GMC 2500HD Duramax I bought new
05 Jeep Wrangler "Willys Edition" 12k miles (I bought new)
85 3/4 ton 4x4 Scottsdale 33k miles original paint
86 1 ton 4x4 SRW Silverado 454 restored
80 1 ton 4x4 SRW Silverado 9,434 original miles!! original paint
95 GMC 1 ton dually 4x4 my dad bought new
95 GMC 3/4 ton 4x4, regular cab 454, 31k original miles
2002 2500HD 4x4 regular cab 6.0L 67k miles
2002 2500HD 4x4 regular cab 8.1L 28k miles
2003 GMC 2500HD 4x4 regular cab Diesel 93k miles
67-72 Parts for sale
Joesjunk is offline   Reply With Quote
Old 04-14-2013, 12:25 PM   #8
Wellgeo03
Wellgeo03's Avatar
Great! Thanks for all the feed back guys!
I can't wait to get this new truck up in the air a bit and get some 35's under it!
Joesjunk, what are you running for a lift?
Old 04-14-2013, 01:00 PM   #9
Joesjunk
Joesjunk's Avatar
its a 4" lift
Old 04-14-2013, 02:14 PM   #10
weider1717
Are you 100% sure thats just a 4" lift? looks like a 6" those 35's have plenty of room looks great!
weider1717 is offline   Reply With Quote
Old 04-14-2013, 03:11 PM   #11
Joesjunk
Joesjunk's Avatar
I thought it might be a 6" lift myself, but the springs have part #8002 rough country, I looked it up and it says 4"???? But I must say it pretty tall, taller than my 71 with a 4" lift and 35's
Old 04-14-2013, 09:29 PM   #12
b454rat
It's because 1 tons have a 2" taller frame than half and three quarters do.
Old 04-14-2013, 10:07 PM   #13
Joesjunk
Joesjunk's Avatar
Thanks for that info!!
