Wiring Gremlins....
Having a little trouble with the ignition on my truck. I haven't started to look yet, but I thought I'd ask here first.
I went to shut it off yesterday, and it wouldn't. I turned the key, and she kept going. I had to unplug the alternator and disconnect the battery. This morning, I hooked the battery back up, and the I could hear the fan coming on, with the key off. It will start fine, but still no turning off. The ignition switch has been "sticky" lately, so I'm thinking the obvious (and easiest), replace the keyswitch. Has some one ran into this and it been something else? Tips? |
![]() Join Date: Feb 2011
Re: Wiring Gremlins....
Before you replaced the switch, clean and inspect the contacts. Sometimes a good cleaning is all you need on these old trucks.
I'm sorry I called you stupid. I thought you knew already. 67 C-20 Custom Camper 68 Nova 396 it does wheelies 2005 Buick Century the one the wife drives 1989 Toyota Tercel to drive when I can't put gas in the first 2. |
