Old 04-08-2013, 04:09 PM   #1
bouncytruck
SKINNY TIRES RULE!
bouncytruck's Avatar
Need quick troubleshooting
I went out to my truck (to head to a job interview) and it wouldn't start. It turns over and if you keep the key in the start position, it acts like it wants to start, but as soon as I put it in the run position, it shuts off.
I'm thinking it's the ignition switch, but I can't get out to test it because I'm at work. Anyone had a similar issue?
bouncytruck 1972 K5
The Hauler 1994 K1500 Suburban
The Daily2010 Kia Soul
Wife's Ride2014 Fiat 500L
bouncytruck is offline   Reply With Quote
Old 04-08-2013, 04:51 PM   #2
Mike C
Mike C's Avatar
Re: Need quick troubleshooting
Points? HEI? On a points setup it gets full 12 volts from starter while cranking then runs through resistor wire when you let off key. Problem in the resistor wire or the connection could get you that.
If it's HEI, could be a bad module. Once again start by checking connections where coil plugs into cap and where 12v switched plugs in to cap.
I had an old Accel BEI that wouldn't fire when cranking. You cranked and cranked and cranked and got nothing. But when you let off the key, it fired. Whacked.
44 Willys MB
52 M38A1
64 Corvette Coupe
68 Camaro 'vert LT1 & TH700
69 Z/28 355 12.6's @110
72 Jimmy 4WD 4spd 4" & 35's
02 GMC 2500HD 4x4 Duramax
Old 04-08-2013, 04:52 PM   #3
cwsohm
cwsohm's Avatar
I've had the same problem in the past. If you are running mechanical points, there is a resistor that is attached to the firewall in the engine compartment on the drivers side. Before putting electronic ignition in my truck, I had to replace the resistor twice in around 20 years... You can get a replacement at most auto stores, however the reproduction ones will look a little different - and I don't think you can mount them the same way as the original.
1972 GMC Jimmy, ZZ4 350
cwsohm is offline   Reply With Quote
Old 04-08-2013, 04:58 PM   #4
Classic Heartbeat
Project Junkie! Fishing Poor!!
Classic Heartbeat's Avatar
Sounds like it could be a switch... I am having problems starting my new CST Blazer myself, so I am just going to convert to HEI ignition. WES
On-line catolog
Classic Heartbeat Pickup Parts
WEHEPP@comcast.net
Call us Toll Free (888) 338-2502
Like Us on Facebook
No appointment necessary.
72 BB Chevy Custom Deluxe / Custom Camper
67 I-6 (Soon to be 5.7 LS1) Panel
68 BB Chevy Short Bed
72 6.0 LQ9 Short Bed Chevy 4X4
Olympia's fastest growing truck parts supplier.
Olympia's home for Wayward Chevys
Classic Heartbeat is offline   Reply With Quote
Old 04-08-2013, 04:59 PM   #5
Classic Heartbeat
If your Blazer had a resister, it was probably installed aftermarket. These trucks and Blazers were wired with a resister wire in the engine harness. WES
On-line catolog
WEHEPP@comcast.net
Like Us on Facebook
Old 04-08-2013, 07:29 PM   #6
IwantaK5
I had a similar problem with a 72' blazer. It would seemingly start when it wanted to and shut off when it wanted to. Ended up being a loose wire on the ignition switch.
IwantaK5 is offline   Reply With Quote
Old 04-09-2013, 12:08 AM   #7
bouncytruck
SKINNY TIRES RULE!
Thanks for the input everyone! Put in a new ignition switch and it fired right up.
bouncytruck 1972 K5
Old 04-12-2013, 09:51 PM   #8
red71cheyenne
Back in the sticks
red71cheyenne's Avatar
Sweet!! Congrats on the quick fix.
1971 Cheyenne C-10 w/700R4 and Tuned Port Injection
1969 K5 Blazer w/Tuned Port
2010 2SS/RS Flaming Orange Camaro
2011 K1500 Suburban
2014 K1500 Pickup
2008 Nissan Altima? The wifes' hoopty
red71cheyenne is offline   Reply With Quote
Old 04-13-2013, 09:49 AM   #9
4oldcars
4oldcars's Avatar
I think it didn't want you to get a job
4oldcars
Driving:
1971 Jimmy w/68 Chev front clip, 1953 Bel Air 2 dr hdtp, 1996 Roadmaster wagon, 2000 Eldorado
The ones I let go:
1931 2 dr sedan, 1935 pick up, 1938 2 dr sedan, 1962 SS 454, 1963 409 wagon, 1970 short bed, 1972 short bed, 1972 sub, 1976 short bed, 1986 long bed, 03 short bed
4oldcars is offline   Reply With Quote
