04-12-2013, 03:17 PM | #1 |
Sanderson CC11 headers
Has anyone got these to work? Sanderson claims they should work, but every vehicle is a little bit different. I have about a 1/4" clearance to the engine mount bracket on the driver's side, the passenger side touches on my 'test fit', will get worse after bolts are snugged (maybe 1/4" interference).
It's the 'bulge' of the bracket that's in the way. How much clearance is ideal/minimal? Does anyone know of some brand with more header clearance? Or engine mounts that sit the whole engine maybe 1/2" higher? If so, is it an 'easy swap', i.e. lift the engine slightly to replace without a removal? I'm a machinist, thinking of making my own, but don't want a time consuming project if there's an easy fix I'm overlooking. Here's the side that is o.k., but you can see where the tube is close. That's where the problem is at on the other side. |
04-12-2013, 03:38 PM | #2 |
Re: Sanderson CC11 headers
The Sandersons that Early Classic Enterprises sells clears just fine. I think they are the CC10's. You can find them on their website. I'm running them with no problems.
Nick "Everyone has a plan, 'till they get punched in the mouth".........Mike Tyson 1968, GMC, SWB, Project 1972, GMC, LWB, Daily Driver, 383, headers, 2.5"/3" exhaust, 200r4, 3.5/5 ECE components. 1972, C/10, LWB, 350 vortec, th350 |
04-12-2013, 04:59 PM | #3 |
Thanks. Just looked at their site. They have their own numbering system (no CC#), but they look like the ones I have. Might have to call Sanderson...
04-12-2013, 05:31 PM | #4 |
When I called to order these, (like a year ago), I recall Mark, from ECE, telling me they were the #10 model. Hope this helps.
04-12-2013, 11:46 PM | #5 |
I bought the Sanderson headers a few years back from Early Classic and they didn't work for me either. I ended up with Stan's Headers made right in the beautiful state of Washington.
04-12-2013, 11:53 PM | #6 |
Soon to find out if the CC11 fit my 72. These were recommended by another forum member who is using them.
1969 RS/SS Z10 Camaro Pace coupe 1972 GMC Short Step buildhttp://67-72chevytrucks.com/vboard/s...=1#post6356218 1979 Mazda RX7 1979 Pontiac Trans Am WS6 & 1979 Pontiac Trans Am 10th Anniversary 1999 Honda Valkyrie 2006 Corvette Z06 2010 BMW 650i |
04-13-2013, 12:24 PM | #7 |
I have the ECE headers which are the cc10's I have at least 3/4" clearance on each side.
Posted via Mobile Device |
04-13-2013, 12:25 PM | #8 |
04-13-2013, 06:28 PM | #9 |
I have them with no problems, supposed to be cc-10
04-13-2013, 08:27 PM | #10 |
Wow, those are slick!!!!
04-13-2013, 08:52 PM | #11 |
Ditto.
Posted via Mobile Device Posted via Mobile Device
67 Chev SWB, 400 SB .040 over, vortec heads, comp XE268 cam, performer EPS intake, edel. 650 AVS carb, 700R4 |
04-13-2013, 09:13 PM | #12 |
If I'm not mistaken the CC11 are for "D" port heads. That may be the only difference between them and the CC10?
04-13-2013, 09:35 PM | #13 | |
04-13-2013, 09:44 PM | #14 |
04-13-2013, 09:46 PM | #15 |
Mine clear no problems
