Closed Thread
Old 04-15-2013, 03:24 PM   #6626
1972SUPERSB
1972SUPERSB's Avatar
Re: What did you do to your truck today!
Installed a new intake and HEI distributor
Jeff
1972 Cheyenne Super SWB 350, Auto, Bucket Seats w/Console, Tach, Factory A/C, P/S ,P/B, Tilt
1998 Chevy 1500 Ext Cab 5.7, Pewter w/blue interior
1972SUPERSB is offline
Old 04-15-2013, 04:04 PM   #6627
Bassman53
Bassman53's Avatar
Smile Re: What did you do to your truck today!
Got Big Orange back on the road Saturday with new timing chain,water pump, thermostat and also added some new valve cover gaskets. Runnin great now!
Somedays your the windshield and somedays your the bug!
Bassman53 is offline
Old 04-15-2013, 06:51 PM   #6628
SCHRUMGMC
SCHRUMGMC's Avatar
I got my money
Going to get the Truck this weekend, really nervous
1971 GMC Sierra
1959 GMC 100
SCHRUMGMC is offline
Old 04-15-2013, 07:26 PM   #6629
FRENCHBLUE72
PROJECT 7DEUCE
FRENCHBLUE72's Avatar
I started taking all the crap off the truck that looks more like a shelf..
GO BIG GREEN GO DUCKS
MEMBER #6377
Project "7DEUCE"
FRENCHBLUE72 is offline
Old 04-15-2013, 07:28 PM   #6630
SCHRUMGMC
SCHRUMGMC's Avatar
Photos French
1971 GMC Sierra
1959 GMC 100
Old 04-15-2013, 07:48 PM   #6631
RRC
RRC's Avatar
Posted via Mobile Device Dropped my buddies of at the upholstery shop today
My build thread http://67-72chevytrucks.com/vboard/s...d.php?t=563712
Instagram: http://instagram.com/rockylakekustoms
Rocky Lake Kustoms
Russ
RRC is offline
Old 04-16-2013, 03:29 PM   #6632
Scott Webster
Sheetmetal Psycho
Scott Webster's Avatar
Pulled the 350 to ship off for repairs. Getting cam and valvetrain gone over / replaced. Fely good to be wrenching on the ol gal. Now I have to see what all I will need to fix or replace while the engines out.
I didn't say you were stupid, but I was thinking it... I need a check up from the neck up!
Project "Rigginstine's Monster"
1971 C-10 longbed 355/4spd
Future mods: 67 front clip
Webby's Rigginations - where everything has potential!
Scott Webster is offline
Old 04-16-2013, 03:31 PM   #6633
tommys72
tommys72's Avatar
Originally Posted by longbed67 View Post
Mocked up my gooseneck plate and fab'ed up some shock re-locators that still use the oem shock size
Damn those rear brakes and rotors are nice
United States Marine Corps 2000-2011
Iraq and Afghanistan veteran
Just living life now and enjoying it and my wife, daughter and son
tommys72 is offline
Old 04-16-2013, 03:35 PM   #6634
tommys72
tommys72's Avatar
moved it out of the garage to work on my DD turd
tommys72 is offline
Old 04-16-2013, 03:50 PM   #6635
Lou Boffa
Lou Boffa's Avatar
I missed it. Having new AC/heating system installed. First time I've let anyone else work on it and I'm having seperation anxiety. Should be done by Friday.
Lou Boffa is offline
Old 04-16-2013, 04:00 PM   #6636
lolo33
lolo33's Avatar
I want to drive my truck ... but problem : new battery, new regulator, but same issue, low battery after some miles. it seems to me that battery passes off by driving, not in the stop !
any idea ?
is it possible that the starter puts itself in short circuit and empties the battery by driving ? I drive only by the day, and just after 10 miles, good new battery is empty
thanks for help
'70 C10 shortbed - 350 Edelbrock equipped - 4/1 headers - 3" flowmaster exausts
'07 MUSTANG V8 convertible - CAI Spectre - Brembo's - 3" flowmaster exhausts
lolo33 is offline
Old 04-16-2013, 04:07 PM   #6637
Lee H
Lee H's Avatar
You should open a new thread in the electrical section for this. Have you tested the voltage output of your charging system both at an idle and at driving speed?
1972 C10 SWB, Air, PS, PB, 350/350THM. Second owner.
1965 Corvette roadster, 44K miles, 327/365 SHP, 4 speed, side exhaust, knockoffs, teak, second owner (bought in 1970), Have ALL numbers matching components.
My frame off restoration thread: http://67-72chevytrucks.com/vboard/s...d.php?t=556703
Lee H is offline
Old 04-16-2013, 04:29 PM   #6638
SCHRUMGMC
SCHRUMGMC's Avatar
Planning on how to get my Truck
1971 GMC Sierra
1959 GMC 100
Old 04-16-2013, 05:18 PM   #6639
VWNate1
VWNate1's Avatar
Post Re: What did you do to your truck today!
Alternator testing is far easier than most think .
Did you place a volt meter across the battery terminals when it's running ? .
That's just one of many tests .
More if you but ask .
-Nate
Geezer
'49 3100 235 W/ Muncie SM420 SOLD
'69 C/10 shortbed sidemount survivor 250 L6 W/ 350TH
VWNate1 is offline
Old 04-16-2013, 05:41 PM   #6640
magwakeenercew2jh
RAT1968 '68 Cab/'71 Parts
magwakeenercew2jh's Avatar
Played with the hood, played with the headliner (carpet from "Big Lots" ), and cleaned up the engine bay a little.
M17
Coarsegold, CA
RAT's shiny now.
But always a rat.
magwakeenercew2jh is offline
Old 04-16-2013, 06:00 PM   #6641
any idea ?
thanks for help
Factory gauges or any add ons?
Sounds like the alternator/regulator are not adjusted correctly
It would be good to see what the differences in the voltage are while driving or what is coming out of the alternator.
As mentioned a small multimeter check across the battery terminals to watch your voltage draw/changes at RPMs is a quick easy way to go.
Also are you required to drive with your lights on all the time over there?
Palf70Step is offline
Old 04-16-2013, 07:54 PM   #6642
mud.man.rj
mud.man.rj's Avatar
100% won't be the starter causing charging system problems, it would have to run with the engine and you would know that.
mud.man.rj is offline
Old 04-17-2013, 02:39 AM   #6643
lolo33
lolo33's Avatar
thanks to you, will verify the charge when engine is running ; battery is charged this morning, so I hope i can start my engine.
battery gauge (factory) doesn't work correctly ==> always good...
what is to say "Sounds like the alternator/regulator are not adjusted correctly" ?
lolo33 is offline
Old 04-17-2013, 05:27 AM   #6644
The regulator and alternator need to work in sync with one another. The regulator can be adjusted to vary the amount of charge being produced. It's been a long time since I had to deal with one, so I would need a manual to see what the adjustments are.
Old 04-17-2013, 05:52 AM   #6645
lolo33
lolo33's Avatar
OK, I bought a regulator item 36-2520 at LMC store. it is not precised for which Ah it is. I thought it was a standard one, because it fits with electrical plugs.
i've any information regarding alternator. Perhaps it's a high Ah powered and the standard regulator does'nt work with.
So do I change the alternator to a standard like item 36-2760-Z (LMC store) ?
First I have to see if charge works or not.
lolo33 is offline
Old 04-17-2013, 06:04 AM   #6646
lolo33
lolo33's Avatar
Then, started my truck. ... 13V, no change when I accelerate !
solutions :
1- condensator ? (not changed)
2- alternator ?
3- regulator ? ==> new one ==> before I changed it, when accelerate alternator gave 18V !!!
lolo33 is offline
Old 04-17-2013, 06:10 AM   #6647
Tshort1
Tshort1's Avatar
^^^^ Agreed wrong section for troubleshooting help^^^^
Tshort1 is offline
Old 04-17-2013, 06:32 AM   #6648
lolo33
lolo33's Avatar
OK done, sorry for disturbing
lolo33 is offline
Old 04-17-2013, 10:59 AM   #6649
BigDaddyV
BigDaddyV's Avatar
I made front upper shock relocation brackets and am about to make the rear ones. Hopefully Ill be able to get them installed friday. Ill post pics soon.
J. Vess, 6'6", Gearhead, Welder, Fabricator, Nutcase
1955 Chevy Stepside "Dudley"
My daily http://www.67-72chevytrucks.com/vboa...d.php?t=760288
1972 Chevy C10, Project "Chevro~Layed out" Nether Storm
Build Thread http://67-72chevytrucks.com/vboard/s...23#post6007523
BigDaddyV is offline
Old 04-17-2013, 02:07 PM   #6650
C10-Rat
C10-Rat's Avatar
Looked at the truck as I walked by.
C10-Rat is offline
Closed Thread
