Old 04-15-2013, 07:31 AM   #1
Green70judge
HELP.. Broken Seat Belt Bolt
So I broke two seat belt bolts the other day in my 86. I have drilled them out as close as I can to the threads with a 3/8 bit.. from what I can tell I did not hit the existing threads..
What should my next step be... Get a tap and tap it to the original bolt size?
Helicoil... and a smaller bolt size?
Green70judge is offline   Reply With Quote
Old 04-15-2013, 07:41 AM   #2
gchemist
BAD BOW-Silverado XST
gchemist's Avatar
Re: HELP.. Broken Seat Belt Bolt
If necessary, go to a bigger bolt. I would not recommend a Helicoil. Safety is nothing to sacrifice. Tap it first. If bolts hold you're okay. If not, then use a bigger grade 8 bolt.
Gerardo a.k.a. Mad Chemist
Silverado XST videos
Old 04-15-2013, 08:17 AM   #3
Green70judge
So then I should take the original bolt somewhere and get a tap to match that?
Old 04-15-2013, 08:56 AM   #4
old Rusty C10
Robert Olson Transport
old Rusty C10's Avatar
I sure would
Bob
1951 International running on a squarebody chassis
"If a man's worth is judged by the people he associates himself with, then i am the richest man in the world knowing some of the fine people of this board"
http://67-72chevytrucks.com/vboard/a...t.php?f=25&a=9 (you can review the site rules here!)
PM Me for your vehicle/parts hauling needs in the North East US or see my Facebook page Robert Olson Transport
Live each day to the fullest.. you never know when fate is going to pull the rug out from under you...
I hate cancer!!
old Rusty C10 is offline   Reply With Quote
Old 04-15-2013, 08:58 AM   #5
LynnJr
I think they went to metric in 1978 on the seat belts so buy a new bolt first so you get the right tap.
I find that once you drill them out they tend to come out more easily with a tap than a easy-out.
LynnJr is offline   Reply With Quote
Old 04-15-2013, 11:32 AM   #6
f.monroe
f.monroe's Avatar
Lightly cut through the threads on one side only. Maybe not all the way through so that you dont damage the captured nut. Spray it with a good penetrating oil .Then take a chisel and collapse the remaining piece of the original bolt inwards to release it from the threaded portion of the nut. They will usually collapse easily and leave the original threads so you can install a new correct bolt.
Frank
Born and proudly residing in a Red State !
f.monroe is offline   Reply With Quote
Old 04-15-2013, 06:57 PM   #7
Deaol
When disassembling my truck for paint I snapped both drivers/passengers. I really over-killed it and drilled out, plated and sleeved the old holes and ran huge grade 8 bolts with a aftermarket 3 point system, probably not necessary but when It comes to safety I would rather over do than under.
* 1968 GMC Swb - 98% done (current restoration)
* 1971 Chevy Lwb - Retired Dump Hauler
* 1982 K10 Longbox - New Dump Hauler
Deaol is offline   Reply With Quote
Old 04-16-2013, 12:04 AM   #8
dieseldawg142
dieseldawg142's Avatar
^^^same, drilled out old bolts, ground off nuts, 3/16 plates & 1/2 gr.8's
dieseldawg142 is offline   Reply With Quote
Old 04-16-2013, 09:02 AM   #9
motornut
78K & 79C Jimmys
motornut's Avatar
if you replaced the floor nuts etc get big washers and even lock washers
I wire wheel or a quick sand blast the under side of the bolt can remove rust scale
good idea i read here,grind the bolt heads square, use a socket
John
1978 GMCJimmy4X4-350/203
1979 GMCJimmy4X2-305/350
Old 04-17-2013, 06:03 PM   #10
Green70judge
Okay So the tap I got says to drill out with a 13/32 bit. However I cannot find a 13/32 bit.. would 3/8 be okay.. from what I can find we are talking about .0313 difference in size..
Old 04-18-2013, 05:10 AM   #11
wraprail
wraprail's Avatar
What size bolt are you using?
wraprail is offline   Reply With Quote
Old 04-18-2013, 08:56 AM   #12
Green70judge
Okay the bolt I bolt I matched from the other bolts... It is a 12mm-1.75x35mm
And the tap for that called for a 13/32 drill bit and I can't locate one. So will 3/8 do?
Old 04-18-2013, 12:24 PM   #13
Green70judge
bump
