#51 | |
Re: My 1972 K5 project
Posted via Mobile Device |
#52 |
Started working on mounting the back seats today. Got everything measure out and marked up. Drilled holes for a few of the brackets. Going to have a buddy come over in the near future to give me a hand putting them in since I will need to have someone on top with a wrench to hold the bolt while I am underneath putting the nuts and washers on.
#53 |
Realized I didn't have installed pics up of the fronts. Here they are mounted. Will need to reupholster them at some point but I really like the fitment and its really nice having the shoulder belt. Pretty comfortable too.
#54 |
Where did you order those seat brackets from?
Thanks Matt Posted via Mobile Device
1951 Chevy 3100/S-10: http://67-72chevytrucks.com/vboard/s...d.php?t=406072 1957 Chevy 3200 1971 2WD Blazer - Sold |
#55 | |
#56 |
Rear seats finally installed! Next step will be to spot weld the nuts in place underneath. I don't want to worry about them coming loose over time. I'm really stoked to have them in finally!
#57 | |
#58 |
![]() Join Date: Jan 2003
Do you have any pics with the seats out and the brackets installed ?
#59 |
I don't but I can take some for you tonight after work.
#60 |
Thanks. I picked up a suburban 3rd row seat, so will be doing something similar as well.
#61 |
Ya no problem at all. Install was pretty easy. The only thing I ran into was that when I mapped out the template, some of the bolts went through on the angled part of the floor board. So I picked up some 1/8 inch steel to use as a mounting plate between the bracket and the floor board. It wasn't really an issue on the front brackets since they are larger and didn't tweak as much. The plates worked out great for the rear brackets. I'll shoot up some pics tonight so you can see what I am talking about.
#62 |
Here you go. Let me know if these help you out or not.
#63 |
Have to do them one at a time because it won't let me do more than that from my iPad.
#64 |
You can see a little in the pictures that the brackets got a little warped from tightening the bolts down but it doesn't bother me. What was most important to me was to ensure that the seats were secure. Once I get the nuts welded tight I won't ever have to worry about it breaking free.
#65 |
Thanks. That gives me a good starting point. I was thinking of welding some round tubing to some 1/4 plates with slots cut in the plates. I will post pics when I get it done.
