Old 04-15-2013, 06:43 PM   #1
hopped up
hopped up's Avatar
need a new yoke
Where do you guys suggest on getting a new rearend yoke for my 12 bolt in my 64? Not sure if i should hit the junkyard or buy new? If i buy new where have you guys purchased from? And how do i know if i have 1310 or 1350 ujoints? The rear is all stock as far as i can tell. Thanks
hopped up is offline   Reply With Quote
Old 04-16-2013, 02:16 PM   #2
hopped up
hopped up's Avatar
Re: need a new yoke
Noone has any recomendations on where to buy from? Or the difference in 1310 or 1350 u joints?
Old 04-16-2013, 02:27 PM   #3
68GMCCustom
Truck and auto performance nut
68GMCCustom's Avatar
Re: need a new yoke
1310's are whats in most...I'd imagine you'd see 1350 in the 3/4 ton trucks?
hard to see...but this is a 1350/1310 u-joint. the 1350 portion is in the d-shaft...the 1310 sized are for the stock rear pinion. The 1350 portion is maybe 25-30% larger then 1310 side. Once I change pinion to 1350 (future D60 rear end upgrade) I can just change the rear joint on the shaft to a normal 1350 u-joint.
Kurt -
'68 GMC short step - NIB '09 LY6 6.0L crate motor w/mods, NIB '12 crate 4L85e w/billet 3k stall Circle D, 3.73 posi 12 bolt, DynaTech f-swap headers, 3/4 drop, handling mods, etc. - my toy
'72 Chevy LWB C-10 Highlander - 350/350 ps/pb/tilt/ac - not original but close
'06 Chevy TrailBlazerSS - LS2/4L70e - little black hot rod SUV - my DD
'18 Kia Sorento - wife's econo-driver
'95 Chevy S10 - reg cab shortbed, LS, 4.3, auto...
my '68's powertrain and chassis build -links broken
A surprise phase - carb to efi -links broken
68GMCCustom is offline   Reply With Quote
Old 04-16-2013, 03:09 PM   #4
hopped up
hopped up's Avatar
Re: need a new yoke
Thanks for the reply. I assumed the 1310 was a stock application. Thanks for the confirmation
Old 04-16-2013, 03:16 PM   #5
gofastnut
gofastnut's Avatar
Re: need a new yoke
I think you can get yokes from a GOOD parts store.
Jeff
96 C3500 Crew Cab Long bed (Waiting on Cool Name)
64 C-10 shortie stepside, "Ole Brownie"
C-10 Club
My achingly slow build: http://67-72chevytrucks.com/vboard/s...d.php?t=508345
gofastnut is offline   Reply With Quote
Old 04-16-2013, 03:23 PM   #6
68GMCCustom
Re: need a new yoke
Pace Performance, Summit - check for Hughes or TCI parts to name a few.
Kurt -
Old 04-16-2013, 04:09 PM   #7
RANDY COX
RANDY COX's Avatar
Re: need a new yoke
I'm in the same boat need 1 for mine also.went to junkyards and they all said the didn't have any,after 5 junkyards I came to realize that they didn't want to take one off of a good rearend,I can simpathise I wouldn't want to take 1 from a good rear either..I checked at advance and they wanted about $175.00.so I'll just keep on lookin...
1964 BBC 402 4x4
RANDY COX is offline   Reply With Quote
Old 04-16-2013, 05:18 PM   #8
hopped up
hopped up's Avatar
Re: need a new yoke
Just ordered a new one from summit. 119 and picked up a crush sleeve too. Might as well just get a new one
Old 04-16-2013, 06:56 PM   #9
RANDY COX
RANDY COX's Avatar
Re: need a new yoke
Cool I'll have to get me 1 when I get some cash...Is it necessary to replace the crush sleeve...when replacing the yoke..
1964 BBC 402 4x4
