Old 04-16-2013, 09:46 PM   #1
WETOWM
Temp gauge problem
My temp gauge in my 70 when i crank to start the engine the gauge goes to full hot and stays there like it is stuck truck has new wiring & temp sensor ? Tryed a differant gauge same thing happened
WETOWM is offline   Reply With Quote
Old 04-16-2013, 10:02 PM   #2
Square_78
Square_78's Avatar
Re: Temp gauge problem
It's wired wrong or grounding out I bet if new sensor and two diff gauges do the same thing.
#teamlongbed
"I refuse to go disc brakes. I actually love drum brakes. It makes for an adventure." - 50bomb
1978 Chevy shop truck - static 6/8"
1970 GMC 1500 - Accuair eLevel Resto-mod http://67-72chevytrucks.com/vboard/s...d.php?t=537497
Square_78 is offline   Reply With Quote
Old 04-17-2013, 07:07 AM   #3
bobs409
1969 Custom 30 wrecker
bobs409's Avatar
It's the resistor on the back. Or more likely, the insulators that go in that area. If I remember, they are just like washers that go on the posts.
Did you have it apart before this started happening?
Bob
63 Impala 283/PG/3.36 (under restoration)
66 Impala 327/PG/3.36
66 Chevelle SS 409/M22/3.55
69 Chevelle 307/PG/3.08 (future restoration)
69 C10 short stepside 454/TH350/3.73
69 Custom 30 tow truck 350/4 spd/4.10 (resto done, CRUISIN TIME!)
71 Cheyenne 20 fleetside 350/4 spd/4.10
71 Chevelle 6/PG/3.08
72 Chevelle 454/M21/4.10
bobs409 is offline   Reply With Quote
Old 04-17-2013, 12:00 PM   #4
wgr2112
There should be a resistor on the back of the gauge between the top and bottom posts. Picture is attached.
I should have a couple of extras if you happen to need one.
wgr2112 is offline   Reply With Quote
Old 04-17-2013, 04:53 PM   #5
WETOWM
is that one for a gauge or a light mine looks differant
Old 04-17-2013, 05:36 PM   #6
71K20chevy
71K20chevy's Avatar
That is the cluster with gauges.
71 K20
64 GMC mud truck
71K20chevy is offline   Reply With Quote
Old 04-17-2013, 07:58 PM   #7
WETOWM
here is the one I have I have 2 of them they are both the same and did the same thing
Old 04-17-2013, 08:47 PM   #8
wgr2112
Different style, but same part.
Must be a sender, ground or other wiring issue.
Old 04-17-2013, 09:07 PM   #9
WETOWM
got it working !! whats the chances of having 2 bad resistors pulled a 3rd from a doner cluster and it works now thanks everyone for you help
Old 04-17-2013, 09:41 PM   #10
Mayo
Cool Truck
Mayo's Avatar
Could the resistor be the problem if the gauge always stays cold?
1968 Chevrolet C20 Longhorn "Cool Truck"
1937 Chevrolet Pickup - Project
Looking for a patina'd 68 50th Anniversary longbed
Mayo is offline   Reply With Quote
Old 04-17-2013, 10:13 PM   #11
wgr2112
Glad you solved the problem!
