Old 04-16-2013, 10:32 PM   #1
OrrieG
OrrieG's Avatar
Re: Radiator overheating already
Bi-pass the temp controller and see if the fan goes any faster. Does the fan power go thru the switch (sounds like it does). Might want to switch to a simple on-off and relay.
Old 04-16-2013, 11:10 PM   #2
sqrlnts
Ok, temp gauge is hooked up and working. Its hard to test an overheating condition at night with the cool air. I refilled the radiator and overflow per Speedbumpauto's recommendation. Just driving around the neighborhood in first gear i could only get the temps up to 190. Just to test the controller I dialed the pot to the max (should be hottest) setting with the truck idling in the driveway and the temperature crept north of 225 before the fan kicked in. At least now I have a reference for what is "hot".
Originally Posted by solidaxel View Post
Why do you have a spring in the upper rad hose?
Those are usually for the lower hose so it does not collapse under high RPM
It was the best fitting hose I could find locally. I have removed the spring.
OrrieG, If I bypass the controller it will run at 100% power all the time (or when switched on) which would defeat the purpose of the unit itself. It is designed to ramp the fan speed to temperature. Hopefully now with the temperature gauge working I can get this dialed in. Thanks.
sqrlnts is offline   Reply With Quote
Old 04-17-2013, 01:06 AM   #3
OrrieG
OrrieG's Avatar
I was just suggesting a check to make sure the fan was operating at full speed when it is supposed to, Thought was maybe all the controls and wiring were not allowing full power to the fan.
Old 04-17-2013, 01:17 AM   #4
solidaxel
solidaxel's Avatar
OrrieG, If I bypass the controller it will run at 100% power all the time (or when switched on) which would defeat the purpose of the unit itself. It is designed to ramp the fan speed to temperature. Hopefully now with the temperature gauge working I can get this dialed in. Thanks.[/QUOTE]
I prefer the 180* thermostat and I have the electric fan se t to come on at 195*
Except when the A/C is on then it is switched with the A/C..
Cycles on and off and stays around 185* +/-5*
53 TuTone Extended Cab 350 4-Spd 3:08 (SOLD)
53 Chevy Moldy pearl green ZZ-4 4L60E 9" 3:25
55 GMC 1st Black Mll (ZZ4) ZZ6 TKO 600 5 sp 3:73
62 Solidaxle Corvette Roman Red (327
340hp 4spd 3:36) C4 & C5 suspension tube chassis
LS 3 4L70E
65 Corvette Coupe 327 350hp 4spd 4:11
78 Black Silverado SWB (350/350) 5.3 & 4L60E 3:42
2000 S-Type 3.0 (wife cruiser)
2003 GMC SCSB 5.3 4L60E 3:42
solidaxel is offline   Reply With Quote
