Old 04-17-2013, 09:48 AM   #11
DD38
Re: Danna 44 and Eaton HO52 Identification Help
I pulled the long side axle shaft and measured it. The inner shaft was 35 5/8" with 30 splines and the outer was 9 1/2" with 19 splines. According to a chart I found, those sizes match a 1967-69 Chevrolet K-20 3/4 ton (35.63" with 30 splines and 9.53" with 19 splines). Not sure how the overall size WMS-WMS is shorter. I might pull the other axle shaft and measure it just to see what I come up with. As for now, I think I will make a tie rod and be done with it until I can upgrade to some disk brakes. Thanks for all the help
DD38 is offline   Reply With Quote
dana 44, eaton ho52
