Old 04-17-2013, 07:24 PM   #1
truckdude239
truckdude239's Avatar
computer tune and harness mods?
who the best place with a good price on programing the computer and cutting teh harness i just bought a 4.8 v-8 with harness pedals computers and accessorys and 460le trans for 1100 dollars?
David fuller
Ase Certified Mechanic
2007 Honda Accord my daily 145kmiles
2002 Honda Accord 4 door With 330k(sisters car)
2005 toyota Avalon 228k( brothers car)
2002 Sububran 5.3 245k
2000 Tahoe 5.3l 378
Old 04-17-2013, 10:46 PM   #2
Daaaanz67
Re: computer tune and harness mods?
Your going to like that4.8 I run one in my 69. Revs like a 327 on steroids. I used lt1 swap and built my harness its not that hard. Sorry cant help with comp programming since I'm in Cali sure there's someone closer.
Daaaanz67 is offline   Reply With Quote
Old 04-17-2013, 11:18 PM   #3
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
A dyno tune will always yield better results (and access to support) than a canned e-tune will. I dislike the concept of having to mail my computer to a tuner, especially if its for fine tuning or future minor changes. Most good dyno tuners should cover fine tuning if for example the shift points, firmness, torque managment etc needs adjustments. While some e-tuners will do small changes like that, they can only ballpark the changes, unless you go all the way to data-logging (which would then put you way past an e-tuner anyway).
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING
MY BUILD THE H8RDCPTR //\\ MY YOUTUBE CHANNEL REV J HD
BR3W CITY is offline   Reply With Quote
Old 04-18-2013, 01:21 AM   #4
truckdude239
Mainly I'm worried about vats And having the emission stuff turnex off then change how it RU s
David fuller
2000 Tahoe 5.3l 378
Old 04-18-2013, 03:04 AM   #5
tinydb84
tinydb84's Avatar
Waitformeperformance has good reviews and does the harness mod and tune for $360
David
Instagram: myfabguy
Old 04-18-2013, 08:51 AM   #6
Robznob11
Robznob11's Avatar
Lt1swap.com mod your own harness! Its easy.w4me did my tune and no issues! Dyno tune is better but they can deffinatly get you on the road!
The Ghost 67 short wide full custom. 550 hp LSX, 4l80E, narrowed 9". Body dropped w/air ride!
........................ ___
.........________//__{\_____
,,,,,,,/__(⊙)___//___/__(O)_/
@disciple2.rc 💪instagram💪
LED TAILS
Robznob11 is offline   Reply With Quote
Old 04-18-2013, 09:36 AM   #7
solidaxel
solidaxel's Avatar
I think Howell Fuel Inj. is at the top of the list for me, both , wire and computer .
I have not seen any comments neg. about them, except the cost !!
53 TuTone Extended Cab 350 4-Spd 3:08 (SOLD)
53 Chevy Moldy pearl green ZZ-4 4L60E 9" 3:25
55 GMC 1st Black Mll (ZZ4) ZZ6 TKO 600 5 sp 3:73
62 Solidaxle Corvette Roman Red (327
340hp 4spd 3:36) C4 & C5 suspension tube chassis
LS 3 4L70E
65 Corvette Coupe 327 350hp 4spd 4:11
78 Black Silverado SWB (350/350) 5.3 & 4L60E 3:42
2000 S-Type 3.0 (wife cruiser)
2003 GMC SCSB 5.3 4L60E 3:42
solidaxel is offline   Reply With Quote
Old 04-20-2013, 10:48 AM   #8
mattcrp1
mattcrp1's Avatar
I just picked up the same 4.8l/4l60e combo for my truck. Did any one keep stock gm fuse block or you use an aftermarket one when modifying the harness?
mattcrp1 is offline   Reply With Quote
Old 04-20-2013, 10:52 AM   #9
truckdude239
If you mod the harness the big one under the hood goes by bye
David fuller
2000 Tahoe 5.3l 378
Old 04-20-2013, 03:57 PM   #10
Robznob11
Robznob11's Avatar
you don't need the stock box its just a headace! most people run a 4 fuse terminal and 2 relays and just make it stand alone. then you use and aftermarket box for the rest of the truck. but if you get the aftermarket box first you can easily run the engine with it and then all wires are marked! lets face it you want to run new wires and fuses on a 40+ year old truck anyhow! you only need a hand full of wires for the truck to run tho!
LED TAILS
Old 04-20-2013, 11:25 PM   #11
Daaaanz67
This is what I used
Old 04-21-2013, 12:26 AM   #12
truckdude239
I still haven't desicde who I want to go with for my harness mod I Dont have time to do it my self
David fuller
2000 Tahoe 5.3l 378
Old 04-21-2013, 07:23 PM   #13
clinebarger
Using the factory fuse box is Very simple & you don't have to cut the harness up, Or even take it off the engine. I will walk you through it if you want.
clinebarger is offline   Reply With Quote
Old 04-21-2013, 07:32 PM   #14
truckdude239
clinee i'd like a little more info on how to do that
David fuller
2000 Tahoe 5.3l 378
Old 04-21-2013, 08:10 PM   #15
clinebarger
You will need a "un-hacked" harness, Fuse box, Fuse box connectors, Fuse box shroud & lid. I will need the year/make/model of the donor truck to give specifics.
Old 04-21-2013, 08:13 PM   #16
truckdude239
2004 silervado 4.8l with a 4l60e trans harness is unhacked DRIVE BY WIRE
David fuller
2000 Tahoe 5.3l 378
Old 04-22-2013, 11:42 AM   #17
mattcrp1
mattcrp1's Avatar
Trying to jump on this train, sorry not trying to hijack. Mine is a 2002 4.8l 4l60e drive by cable. thanks
Old 04-22-2013, 12:15 PM   #18
mattcrp1
mattcrp1's Avatar
It looks like lt1swap.com has the break down for using the stock fuse box.
Old 04-22-2013, 07:46 PM   #19
clinebarger
Give me some time & will get all the pin-outs.
Old 04-23-2013, 11:51 AM   #20
eagleuh1
eagleuh1's Avatar
x2 on using stock fuse box, connectors. Its a little ugly and bulky, but super simple and has lots of left over relays and fuses for the other little things in life.
eagleuh1 is offline   Reply With Quote
Old 04-23-2013, 01:38 PM   #21
Hart_Rod
Hart_Rod's Avatar
Do you have this info for a 2013 Camaro SS 6.2/6L80?
Hart_Rod is offline   Reply With Quote
Old 04-23-2013, 07:37 PM   #22
truckdude239
do i even want to know how much ti cost for that motor and trans hart lool?
David fuller
2000 Tahoe 5.3l 378
Old 04-23-2013, 09:21 PM   #23
Hart_Rod
Hart_Rod's Avatar
, I quit counting....
Old 04-24-2013, 01:08 PM   #24
Jon01
Jon01's Avatar
I've chopped up a few harnesses in the past.
This go-round I spent the $ to have it done professionally. I had Bill @ BP Automotive do mine and he did a fantastic job.
$350 and it came back looking great.
He's a sponsor on ls1tech.
64 Biscayne - 230/PG, Accuair E-Level, 18/20 Bonneville C's.
68 Charger R/T - #'s matching 440/auto car, 499/727/3.91.
68 GTX - 440/4-speed, Dana 60. 44,000 miles.
71 SWB C10 - LQ4+S476r
06 Duramax - LBZ - Exhaust, EFI Live, etc...
Jon01 is offline   Reply With Quote
Old 04-24-2013, 01:14 PM   #25
truckdude239
Cline I thank you for the help I was suppose to get the fuse box but they sold the fuse box out of it before I picked up the motor so all I got was an in uncut harness
David fuller
2000 Tahoe 5.3l 378
