#176 |
Re: Parked Indefinite
Thanks guys!
Flipped the box on today and as expected I'm going to have to lower the sides down/raise the floor. Have an idea of what to do and will hopefully get started tomorrow ![]()
#177 |
Amazing work so far man, I've read every post from the beginning, you have awesome fab skills!!! Will be subscribing
!! Keep up the awesome work
DustinCurrent Projects: 79' Chevy C10 SWB - 454BBC with TH350 tranny. just a few mods. LOTS of work in progress!! 89' Pontiac Firebird - 350SBC swap with 700R4, few bolt ons. On back burner for now. (Daily Driver) |
#178 | |
![]() One side down
#179 |
A day should have 30 hours.
Sick, priceless and speechless. Can't think of any other words.
Oh wait..... Awesome. |
#180 | |
Rounded out the day by dropping the driver side and bulkhead down to match the rest. I thought this was going to be a bit of a job, but turned out to be piss easy! Few pics: ![]() ![]()
#181 |
looks great man
#182 |
Big enough exhaust for ya?!
#183 |
This is the type of thread that gets other guys out to work on their trucks.
Wow, great job. Tons of custom work. I'd like to see a vid of this going down the track! |
#184 |
![]() Join Date: Oct 2008
Wake up, wave magic wand, presto, bedsides dropped! Or is there more to it than that? Do tell or post pics please.
#185 |
#186 |
6>8 Plugless........
![]() Join Date: Sep 2007
I'm guessing he cut the inner bedsides at the lip where the floor bolts, and removed x amount and welded the lip back on. Then did the same to the front bed panel. That's just my guess though.
Ryan 1972 Chevy Longhorn K30 Cheyenne Super, 359 Inline 6 cylinder, Auto Trans, Tilt, Diesel Tach/Vach, Buckets, Rare Rear 4-link and air ride option Build Thread 1972 GMC Sierra Grande Longhorn 4x4 1972 Chevy Cheyenne Super K20 Long Step side tilt, tach, tow hooks, AC, 350 4 speed 1972 C10 Suburban Custom Deluxe 1969 Chevy milk truck 1971 Camaro RS 5.3 BTR STG3 Cam Super T10 1940 Ford 354 Hemi 46RH Ford 9" on air ride huge project Tired of spark plugs? Check this out. |
#187 |
Happy to be here
![]() Join Date: Mar 2000
Details on the bed floor please.
#188 |
Sorry for the lack of update guys, just hasn't been much progress to share. Anyways, as far as the box raising, I decided to move the floor up 3.5" so it would be even with the body line on the inside of the box. Even though I only had a body channel of 2" to deal with, the extra 1.5" gave me some extra room underneath for exhaust, fuel cell, axle, etc. Also it made it so the wheel tub would land on the upper body line inside the box. Just had to make some 1.5" risers which you can see here:
![]() Back to the box itself, I wanted to avoid welding along the entire length of the box side, so when I just drilled new holes 3.5" up from the old ones. On the uppermost holes, where you can't reach underneath to put a nut on, I just welded nuts where they needed to be: ![]() For the bulkhead i bought some 1/4" x 1" flat bar to make up for the gap that occurs when you lower it down the 3.5'". I drilled and tapped the bar to correspond to the holes in the box floor and drilled bigger holes in between so I could plug weld the bar to the bulk head. Here's a pic of it bolted back in place with the bar in between: ![]() I was going to do the same thing with the gaps in between the tubs, but haven't got around to doing it yet, but here's a pic the shows the bar better: ![]() Last thing I had to do was cut a square section out of the floor at the back so the box sides could slide down. Didn't get a pic of that unfortunately, but maybe you can see it in this pic: ![]() Hope that clears it up!
#189 |
#190 |
#191 |
Your build is so killer! Can't wait for the first burnout vid, I'll post my dually burnout right after
![]() Posted via Mobile Device
1979 Chevy Dually Crew 4X4 454, D60 Tru-trac, D70 Detroit Locker, 3.73, 4L80E/NP205 1971 GMC 3/4 Ton 4X4 |
#192 |
Nice work on the bed!
Max Max's bagged 81 81 rcsb bagged, 22s, build in progress 09 ext cab, 24" U2's, DD sub/amp |
#193 |
Nice work! I like that you still have a usable stock looking bed, unlike many that you see on here.
![]() Posted via Mobile Device |
#194 | ||
![]() Quote:
Think I'm pretty much done with the fuel door, though I might try to even out the gaps a little more. Here's how it came out: ![]()
#195 |
I'm really digging the fuel door. How do you get it opened without prying up on the edge?
#196 |
#197 |
Nice job on the fuel door mod.
Your moving along quickly and will be on the road soon. |
#198 |
You got me! I haven't quite figured that part out yet, but for the meantime i just have a magnet on it. Something to grab on to for now, but easy enough to take off when I know what I'm going to do
#199 |
#200 |
Thanks Bomp! Hoping to be driving this thing soon!
| Bookmarks |
