Old 04-18-2013, 10:59 AM   #1
klutz51
Brake light switch
Has anyone used a inline hydrolic brake switch for rear brake lights? Running the power brakes under the cab, and was thinking about using the inline switch for the brake lights, dont know if that is a good idea or not or has anyone had problems. Thanks
klutz51 is offline   Reply With Quote
Old 04-18-2013, 12:34 PM   #2
buggy5872
buggy5872's Avatar
Re: Brake light switch
There are a lot of vehicles out there with that type of switch. I have used them on my race buggy back in the day and never had a poblem with them. All air cooled vw came with that type.
___________________________
1959 Apache Short Fleetside,
1959 Apache NAPCO Long Stepside,
1957 3100 with 59 fleetside bed
1957 5700 LCF Crew Cab "Big Bertha",1959 GMC F370
1958 GMC 600, 1946 Chevy, 1959 Viking 60 LCF
1974 Elcamino SS, 1979 6500 GMC Tilt Bed Wrecker
Big Bertha Build
buggy5872 is offline   Reply With Quote
Old 04-18-2013, 12:39 PM   #3
mr48chev
mr48chev's Avatar
Yep most Fords had them up thorough at least the late 60's and I have one on the 48 but I'd much rather run the stock switch unless you moved the pedal assembly then i'd figure out a switch to work on the swinging pedals under the dash before putting in an inline switch. Reason: it seams I changed the inline brake light switch every other year on my truck and years ago working in shops I changed a lot of Ford inline brake light switches but very few GM switches.
My ongoing truck projects:
Old 04-18-2013, 01:28 PM   #4
NEWFISHER
NEWFISHER's Avatar
I picked up a VW one to plumb in to the system at the master as soon as I upgrade from single master to dual. I will run the stock switch for lights, looks etc and will hide the hydro one for trailer brake signal and ignition/starter cut out ( hidden button under dash to bypass) for security
NEWFISHER is offline   Reply With Quote
Old 04-18-2013, 04:16 PM   #5
G&R's57GMC
G&R's57GMC's Avatar
Careful Newfisher That VW switch is metric not NPT.
You could use a relay off the stock switch for the Trailer Brakes.
Glen & Jane's Rides
‘57 GMC NAPCO Long Bed V8 4 speed Bought 2008
7 other cars & trucks , 5 trailers
'56 Chevy Long Bed I6, 4 speed Bought 1990 Sold 8.22.2020
’56 GMC Suburban Pickup V8, 4 speed Hydramatic Bought 1996 Sold 10.11.2020
My Other Tinkerings http://67-72chevytrucks.com/vboard/s...75#post8967275
G&R's57GMC is offline   Reply With Quote
Old 04-18-2013, 04:21 PM   #6
G&R's57GMC
G&R's57GMC's Avatar
I agree !
I too changed many a Ford hydro switch and the mechanical switch that came out next. I can't believe Ford used those 2 switches for as long as they did, But I made a bunch of bucks changing them
Glen & Jane's Rides
Old 04-18-2013, 05:41 PM   #7
NEWFISHER
NEWFISHER's Avatar
Thanks for the heads up. I have a "T" fitting with the standard and metric thread already waiting for the swap.
Old 04-18-2013, 06:22 PM   #8
SCHRUMGMC
SCHRUMGMC's Avatar
Lord, I wonder how my '59 will be like with Brakes
1971 GMC Sierra
1959 GMC 100
SCHRUMGMC is offline   Reply With Quote
Old 04-19-2013, 12:22 AM   #9
1project2many
In addition to frequent replacement, the pressure switches take slightly longer to close. Sure, it's a tiny amount of time but imo the stock brake lights being small and mounted low on the truck don't get noticed as quickly so anything that delays the reaction of the driver behind you isn't good.
1project2many is offline   Reply With Quote
Old 04-19-2013, 12:02 PM   #10
mknittle
mknittle's Avatar
Don't get too far ahead of yourself! you can get overwhelmed! Cross that bridge when you come to it.
Mark
My GMC build.
http://67-72chevytrucks.com/vboard/s...d.php?t=536602
mknittle is offline   Reply With Quote
Old 04-19-2013, 01:03 PM   #11
parkwood
parkwood's Avatar
Summit sells a low pressure switch made by Ron Francis.. part # rfw-sw32 takes very little pressure to turn on.. i've had great luck with these.
parkwood is offline   Reply With Quote
