5 lug conversion
Who ever had my truck before me converted my truck to 5 lug. It looks like they had the factory axels drilled and tapped to 5 lug. But the drums look like crap. They took a torch and cut the holes larger. I would like to get new drums. So will a drum for a 71 work? Diameter of the drums are the same and the bolt pattern on the truck and the 71 drum are also the same. Am I missing something but this seems like it will work?.
![]() Join Date: Mar 2012
Re: 5 lug conversion
They will work, as long as diameter and shoe width are the same,
Shoes are the same for both years and the drums off a 1971 match up, well except for the center hole. I was thinking about having the center hole on the drum made bigger at a local machine shop. Any reasons this would not work?
#4 | |
![]() Quote:
You'll get new diff'l lube, check axle-bearing surfaces and seals, and have the job done more-nearly correctly--all in all, the next best thing to buying correctly-mfg'd NEW axles. **SHOULD YOU FIND BAD BEARING SURFACES, IT'S TIME TO BUY NEW AXLES WITH 5-LUG PATTERN AND CORRECT REGISTER MFG'D FOR THE CONVERSION.** BTW: Based on the hack job done by prev. owner, I'd bet front hubs were re-drilled with drums hacked to "fit", also???--esp. if he put drums on the front instead of discs. If so, you'll need to have those hubs turned to fit the center of the new drums that you'll need to buy for the front. BE SURE TO CHECK THAT FRONT. Sam |
#5 | |
thank you. I plan on doing an axel conversion eventually. Have some other things I want to do first.
#6 | |
WHEN THEY DRILLED THE HOLES FOR THE 5 LUG THEY SHOULD HAVE MACHINED THE AXLE END DOWN TO THE PROPER DIAMETER.... LIKE THIS: http://kieth.smugmug.com/Trucks/66-G...Rfcq&lb=1&s=X2 |
Nice looking job on the axles, Kieth! [I've even seem some done w/out fill-welding 5 of the orig holes...ughhh!]
Sam |
