Old 04-18-2013, 05:22 PM   #1
gutts
Mongrel truck
Hello
Thank you in advance for any help or comments.
I am new to this forum . I have been reading a lot , but cannot find the right info.
Here is my story. I received a truck a few years back. I let it sit in the backyard for a time. It is , I was told a 1979 cab on a 1987 frame, with a home made dump body on it. It is a 4x4. The motor is a 305 with a overdrive transmission. The truck does not have lock out hubs. It is tbi.
I have started to work on this truck. I want to fix it up a little . The cab and frame are in good shape. The motor. And other mechanicals are a bit rusty. I have replaced the brake,power steering and transmission cooler lines.
I have not been able to get the motor running correctly. I am looking for a picture or diagram with the various control parts and vacuum lines on it .
On this truck the water temp sending thing is on the front of the manifold. I assume the throttle position sensor is on the passenger side bottom of tb. What does the egr do? Does this truck have a computer and if it does where is it?
The wire that you disconnect to time the motor, if I disconnect it the truck won't start.
What I need to do is identify all the pieces first.
gutts is offline   Reply With Quote
Old 04-18-2013, 06:16 PM   #2
b454rat
Re: Mongrel truck
It has a computer, or TBI won't run. It's behind the glovebox, silver box thingy....Timing I think is a brown wire.
2000 Chevy Tahoe Limited 3/5" drop
2000 GMC CCSB 454/4L80 6” lift SAS
1999 Chevy CCSB 454/NV4500 4” SAS
1999 GMC Yukon stock SAS 6"
Old 04-18-2013, 07:19 PM   #3
gutts
Re: Mongrel truck
Thanks just gathering info right now.
Old 04-19-2013, 06:22 PM   #4
gutts
Re: Mongrel truck
Can someone tell me what the first year for fuel
Injection was ?
Old 04-19-2013, 06:58 PM   #5
pwradder
pwradder's Avatar
Re: Mongrel truck
as far as i know, it was 1987.
1977 srw cc lb 396/700r/4:11's/6'' bds lift/ 35's. sold
1986 suburban 350/700r/3:73's 31's: parted out.
1980 silverado swb 5.3/700r/ 2'' drop/ daily driver. sold
1985 c10 long bed 5.3/700r/2'' drop/17" wheels/ daily driver. sold
1970 c10 long bed-new project! getting ready for the 6.0
pwradder is offline   Reply With Quote
Old 04-19-2013, 08:34 PM   #6
gutts
Re: Mongrel truck
Thank you PW
Your in windsor locks ? i live just south of middletown.
I am trying to get this truck running decent, One thing leads to another !!
Old 04-19-2013, 08:44 PM   #7
pwradder
pwradder's Avatar
Re: Mongrel truck
that's cool, i used to live in middletown. i know how that "one thing leads to another" thing goes! good luck and keep at it.
