57 wiper motor
Are the standard wiper motors on a 57 chevy a combination vacuum and electric? The motor has a wire sticking out the side (ground?) and has a cable with a knob that looks like a vacuum line connects to it. What gives?
Re: 57 wiper motor
i thought all the 55-59's had the crappy vacuum motor in it
My name's Tim and I'm a truckaholic My 56 Chevy shop truck build http://67-72chevytrucks.com/vboard/s...d.php?t=562795 |
![]() Join Date: Jun 2011
Re: 57 wiper motor
The cable controls the slide switch that is in the motor. The wire comming out is the hot wire and the the motor grounds through the bolts that hold it to the body. As you turn the knob it moves the switch. It will have off...low...high settings. It seems a little goofy but thats how it works.
___________________________ 1959 Apache Short Fleetside, 1959 Apache NAPCO Long Stepside, 1957 3100 with 59 fleetside bed 1957 5700 LCF Crew Cab "Big Bertha",1959 GMC F370 1958 GMC 600, 1946 Chevy, 1959 Viking 60 LCF 1974 Elcamino SS, 1979 6500 GMC Tilt Bed Wrecker Big Bertha Build |
Re: 57 wiper motor
So this is the electric motor and has nothing to do with vacuum? That cable going to the sliding switch is what is funky. I think mine may not be working right. Anybody know where you might get one?
Re: 57 wiper motor
Jim, aftermarket replacement wiper motors are available but pricey (~$180). Also know that in 58 they changed wiper motor styles so 55-57 should be the same. I will add wipers at some time in the future and was looking at using this as a cheap alternative. Would take some DIY brackets but I think its possible.
Re: 57 wiper motor
What is your doing that makes you think it is not working correctly?
Re: 57 wiper motor
gmjim4x4, I have the same electric motor in my 57. I see two ways to possibly go.
I see in Classic Parts they have a rebuilt unit advertised now. I see in LMC there is an electric replacement listed. I haven't looked any further into which would be the better way to go. I'll be curious as to what else you find. Jim |
Re: 57 wiper motor
I was talking about the cable not working. (the motor may not be either, I havent got that far yet) I turn the knob and the switch does not move. I will fool around with the cable off the motor and also see if I can get the motor to run by jumping it to a battery and grounding it somehow. That link with the 30$ motor looks very interesting! Thanks you guys for your help, it is greatly appreciated. Jim
#9 | |
Re: 57 wiper motor
Pics might help everyone get on the same page as well. Let us know what you find. |
Re: 57 wiper motor
[attach]1095000[/attach These wiper motors look like the one I have. |
#11 | |
Re: 57 wiper motor
Re: 57 wiper motor
i didn't realize that electric wipers were an option on 57, i thought they came out in 59
the rotary cable control is the same for vacuum and electric you can also slide the switch by hand to test the motor/switch i shaved my dash and lost the option to use the factory controller i use a choke cable to operate my wipers in the hole next to the headlight switch out is off, in is on. a little goofy but it works, though i have never used my wipers rainX is your friend ![]() ![]()
cool, an ogre smiley ![]() how to put your truck year and build thread into your signature shop air compressor timer |
Re: 57 wiper motor
Yes gmjim4x4, that's exactly what mine looks like.
buggy5872 is right, the switch on the dash is like a choke cable but with a rotary instead of a push pull. Mine, due to age was a little sticky but it freed up with a little lubricant. My wiper motor would probably work great but the wire that passes through the housing has deteriated and is shorting out. At this point in my rebuild I'd just asoon replace the whole unit, I've found after many restorations, it's always the small parts that I didn't replace that fail later on me. Jim |
#14 | |
Re: 57 wiper motor
The wire in the wiper motor in big bertha was broken off. I took the motor apart and sodered a ne wire on....if you chose to do this, be careful and mark the motor housing and put it back in the same position. If you turn it 180 degress the motor runs backwards. If I remeber correcttly it was a bugger to get the thing back together due to the location of the brushes. I have found that these motors generally do not see much use and are just dirty and need a good cleaning to get them operating again. You could also slide a piece of heat shrink over the wire and through the hole....probably the easiest method. Shane
#15 |
Re: 57 wiper motor
My electric motor came out of a 57 GMC utility linemans truck.
#16 |
![]() Join Date: Dec 2012
Re: 57 wiper motor
I am guessing the 57 Wiper motor is the same as the 59 ?
1971 GMC Sierra 1959 GMC 100 |
#17 |
Re: 57 wiper motor
55 to 59 is all the same wipers setup
electric and vac all use the same linkage and control
#18 |
Re: 57 wiper motor
Oh alright I'm going to look for a used wiper motor
#19 | |
Re: 57 wiper motor
just don't go and spend a bunch on a shot wiper motor, a good friend of mine who has been driving these trucks for 30 years said he has never had good luck getting them rebuilt. Here is a video on how to bench test the unit. |
#20 |
Re: 57 wiper motor
For electric wipers the 55-57 used a cable operated "slide" type switch,
the 58-59 used an electric operated switch that plugged into the body of the motor, just like the picture above. I think the vacuum type were all the same from 55-59. Back in the day I scrounged a few vacuum wiper motors from 55-59 trucks in salvage yards and the all were direct fit on my 59 and my father in law's 55. I ended up finding a NOS vacuum wiper motor some years ago and I run it on my truck. I don't think the vacuum units are all that "crappy", if you also use the correct fuel pump. Vacuum wipers require the fuel pump/vacuum pump combination. |
#21 |
Re: 57 wiper motor
Alright, Thanks Sqrints.I believe the one on the truck I am getting has either a new one or the original, I should have asked him while I was there the first time
