04-19-2013, 03:05 PM | #1 |
BOAT cam in a truck? Opinions please.
I have been looking to replace the tired 425 Olds in my 3/4 ton. One of the rods is making a noise and telling the others that he is longer than them. I like the Olds power, economy and reliability not to mention the truck is already set up for Olds.
I have found a replacement Olds engine for a reasonable price. It was built for a jet boat though. I don't really know much about the boat cams except they are used in apps that turn 4500 r.p.m. for extended periods of time and make good vacuum down low. Would/could this be good in a truck app??? Should I just go back to the small block Chevy and be done with it?? Thanks in advance for all opinions.
1970 Longhorn, Front Disc, 350/4 bolt, 882 heads, HEI, Edelbrock, 700R4, HO-52/4.11. 1996 Corvette, Collector Roadster, LT4, 396, 450RWHP, 6sp, 4.11/Dana44/posi 5 point roll bar And let us not grow weary of doing good, for in due season we will reap, if we do not give up. Gal 6:9 |
04-19-2013, 04:32 PM | #2 |
Re: BOAT cam in a truck? Opinions please.
it's just right if you frequently run your truck at 4500 rpms if you don't then it isn't what you want
common sense isn't so common anymore |
04-19-2013, 04:49 PM | #3 |
1972 K20
Boat cams run very little overlap (intake and exhaust valves open at the same time) due to them having water cooled exhaust. Would be close to a stock non performance cam and probably make good torque which I think is good for a DD truck.
04-19-2013, 07:21 PM | #4 |
the boat guy
Lobe seperation 112* comp xm278h the most extreme cam I could find for water cooled manifolds. One thing to remember A LOT of jet boats don't have water cooled exhaust manifolds and all bets are off on what kind of cam might have been used. Posted via Mobile Device
67, swb, fleet, tach, throttle, 5.3, 4l60e, 3.73's, fuel cell, 5 lug, p.d.b., 4-6 drop. great little truck 66, stevens drag/ski 18' silouette, 350, 2.02 doublehump heads. comp extreme marine 278 cam, vette 7 fin valve covers, old polished edelbrock intake, velvetdrive, casale v-drive, adj cavitation plate. 28, model a rpu project, |
04-19-2013, 08:17 PM | #5 |
if the olds engine is cheap enough they do still sell camshafts for old olds engines
71c-10 350/2004r/4:11 lowered3/4 longbed/dead by hurricane MEANING OF DEATH::::: SOMEBODY ELSE GETS YOUR STUFF DONT BELIEVE EVERYTHING YOU THINK TAKE MY ADVISE;I DON'T USE IT ANYWAY Last edited by cdowns; 04-19-2013 at 08:37 PM. |
04-19-2013, 08:18 PM | #6 |
Answered your own question? Have it rebuilt. If you buy a 350 crate engine, then all the accessories, intake, carb, dizzy, and everything else you would need, you'll have $3000 to$ 3500 in the swap.
Jesse James 1967 C10 SWB Stepside: 350/700R4/3.73 1965 Ford Mustang: 289/T5-5spd/3.25 Trac-Loc 1968 Pontiac Firebird: Project Fire Chicken! 2015 Silverado Double Cab 5.3L Z71 2001 Jeep Wrangler Sport 4.0L 5spd 2020 Chevrolet Equinox Premium 2.0L Turbo 2011 Mustang V6 ~ Wife's ride American Born, Country by the Grace of God 1967 CST Shop Truck Rebuild! My 1967 C-10 Build Thread My Vintage Air A/C Install Project "On a Dime" Trying my hand at Home Renovation! 1965 Mustang Modifications! |
04-19-2013, 09:05 PM | #7 |
There's no replacement for displacement.
Nick Old Mustard, 1972 Chevy C20, 350, TH350, 4.10 Dana 60 rear, owned since I was 16 in 1986 http://67-72chevytrucks.com/vboard/s...d.php?t=545356 Blue Bell, 1987 K20, 6.2L Diesel, TH400/NP208, 4.10 gears Ustahav 1976 K10, 350/350/203, Gov Loc, Yooper beater trail truck. |
04-19-2013, 09:10 PM | #8 |
Gotta be careful when getting cams for Olds engines, some of the early 400s and 425s had a 45 degree lifter angle while most later ones(455s) had 39 degree. If Im not mistaken, most(all?) 425s had forged cranks though.
Build thread:http://67-72chevytrucks.com/vboard/s...d.php?t=534956 |
04-19-2013, 09:39 PM | #9 |
Boats and trucks require the same thing...low end torque!
Turp Mcspray New life for an old 2wd, farm blazer http://67-72chevytrucks.com/vboard/s...d.php?t=505987 My Blazer build http://67-72chevytrucks.com/vboard/s...d.php?t=342299 |
04-20-2013, 12:12 AM | #10 |
I am a Inboard Boat Mechanic and most boat engines start as factory longblock truck engines or car performance engines then are finished out with wet exhaust, marine waterpumps (which are diff than cars and trucks because they need antifreeze to lubricate) and flame arrested starters, alts, ignitions and marine fuelpumps and carbs or fuel inj. Some intakes have brass water jackets for aluminum because electrolosis will eat up aluminum. But have seen ppl put all kinds of cams and car parts in them so you never know.The new 6.0's have 409 hp with closed water cooling systems so the engine has antifreeze in them with a freashwater cooled heat exchanger and wet exhaust.
My build thread http://67-72chevytrucks.com/vboard/s...d.php?t=531265 72 Cheyenne Super 90 Z71 S.B. 434 C.I. Stroker 78 Camaro Z28 (gave to wife she is restoring it) Last edited by Roninwolf; 04-20-2013 at 12:20 AM. |
04-20-2013, 11:00 AM | #11 |
the boat guy
My only hope is that a nice jetboat isn't going to die to keep a truck on the road. Most old hotboats sell for less than what it would cost to build the drivetrain. So many old boats have been scrapped after stealing their engine.
04-20-2013, 02:03 PM | #12 |
put it in and use it like it is, on weekends strap a set of ski's to the tires and take it out and fish from the bed. win win
72 Cheyenne LWB |
04-20-2013, 06:43 PM | #13 | |||
"I ain't nobody, dork."
Gary
