Old 04-20-2013, 10:58 AM   #1
weider1717
No exhaust manifold gaskets when removed? do they need milled?
Removed for the 1st time my 87's manifolds restored them now ready to put them back on there were no gaskets when I removed them. Should I take them to a machine shop and have them milled incase they're warped any? or do they usually not leak when put back on?
thanks
weider1717 is offline   Reply With Quote
Old 04-20-2013, 12:24 PM   #2
motornut
78K & 79C Jimmys
motornut's Avatar
Re: No exhaust manifold gaskets when removed? do they need milled?
I'd use a steel ruler or other straight edge to check
run it flush across them all
not sure if you would benefit from running small grinding wheels inside to clean up casting marks etc
fine sand paper the mating surfaces
John
1978 GMCJimmy4X4-350/203
1979 GMCJimmy4X2-305/350
Old 04-20-2013, 12:27 PM   #3
88Jimmy4x4
88Jimmy4x4's Avatar
buy the gaskets and put them on, they should have them. I restored mine and used gasket from kit and I have no leaks.
2008 Silverado Z71 RCSB
1991 GMC Jimmy 4x4
1976 GMC Sierra C15 SWB
88Jimmy4x4 is offline   Reply With Quote
Old 04-20-2013, 12:55 PM   #4
weider1717
when you removed yours are you saying they had gaskets or no? maybe mine have been off before but I really don't think they have.
Old 04-20-2013, 12:56 PM   #5
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
They never had gaskets originally but it's standard procedure to put gaskets in once they've been removed the first time. I wouldn't worry about having them planed. They don't usually warp appreciably enough to cause sealing issues when used with gaskets.
Tx Firefighter is offline   Reply With Quote
Old 04-20-2013, 08:14 PM   #6
donut
donut's Avatar
My '86 called for copper RTV for the gaskets. Checked when I was trying to fix exhaust leaks.
'86 C-30 dually, 454/tbh400
'73 K-20 350/350/205 (sold )
I'm kinda like duct tape- no real purpose, but handy to have around.
donut is offline   Reply With Quote
