Old 04-20-2013, 09:52 PM   #1
1970CarolinaK10
Headlights
Hey all-
I have a 1970 K10. The headlights turn on when i flip on the brights and turn off under dim. Is it the lights or wiring? Where do I start? Thanks!!
AW
1970CarolinaK10 is offline   Reply With Quote
Old 04-20-2013, 10:11 PM   #2
ole dollor
ole dollor's Avatar
Re: Headlights
i would start with the dimmer switch and see if its bad, i have seen head lights go bad on one filament on both bulbs but not often. also clean and check your grounds and plug ins at the head lights...just a few things to start with...good luck and welcome to the forum ....
ole dollor is offline   Reply With Quote
Old 04-20-2013, 10:13 PM   #3
1970CarolinaK10
Re: Headlights
Thanks!! (Sunday's task is fix the headlights) Great forum.
AW
Old 04-20-2013, 10:14 PM   #4
c10monkey
c10monkey's Avatar
Re: Headlights
When on dim, move the plug on the back of the headlamp to see if it's not just a bad connection. That's where I would start..
1971 Chevrolet C10 Inflation Fighter
1994 C3500 Crew Cab Dually 454
c10monkey is offline   Reply With Quote
Old 04-20-2013, 11:31 PM   #5
Stocker
20' Daredevil (Ret)
Stocker's Avatar
Re: Headlights
All good ideas. My guess is dimmer switch.... also check the connector to the dimmer switch.
- Mike -
1972 K20 LWB 350/350/205
RIP El Jay
