Old 04-21-2013, 01:45 AM   #1
rigon4
rigon4's Avatar
It has been a long time and need help/answers
Its been a couple years after a long hard divorce but picked up a 1987 short wide and it needs a gas tank and my question is can I put the gas tank out of my 1985 short step with a Carb into the 1987 that is a this set up? Thanks all and its nice to be back
1981 K-5 Blazer 2wd
1985 C-10 Short step
1988 C-10 Suburban
rigon4 is offline   Reply With Quote
Old 04-21-2013, 07:10 AM   #2
S10Fan
Old Heap Driver
Re: It has been a long time and need help/answers
Divorce, been there done that 30 years ago.
I'm not sure on the fuel tank. The 87 probably has an in tank pump. Not knowing your money situation, new tanks are pretty cheap, under a $100.00 on Rockauto.com. There are others on eBay reasonably priced.
_____________________________
Bryan
'99 Silverado 1500, 4.3, 5-speed, reg cab, short bed
'50 Chevy 2DR Hard Top, 350/350, M2 Front End, 3:08 gear, cruiser.
'40 F**d Sedan, all Chevy power, Heidt's front end, TCI rear, nice driver.
S10Fan is offline   Reply With Quote
Old 04-21-2013, 07:26 AM   #3
rigon4
rigon4's Avatar
Im going to fuel cell my 85 and the tank is mint in it so if it can work why not use it in the 87 ya no
1981 K-5 Blazer 2wd
1988 C-10 Suburban
Old 04-21-2013, 08:09 AM   #4
squaredaway
squaredaway's Avatar
If I recall correctly, the 87 has baffled tanks because of fuel injection. I do not think retro fitting it would be a good idea. I could be wrong.
1987 Silverado
6.0/4L80E
5/7 Drop, 20x8.5(245/45)/20x10(295/45) Coy C5s
squaredaway is offline   Reply With Quote
Old 04-21-2013, 10:43 AM   #5
Zane M
You can run the '85 tank in your '87.
You will not want to run less than 1/4 of a tank(which we shouldn't do anyway) because the lack of baffling can allow the pump to get starved of fuel when cornering or going up/down steep grades.
Zane M is offline   Reply With Quote
Old 04-21-2013, 06:29 PM   #6
wraprail
wraprail's Avatar
Hell I can barely afford to keep my tank 1/4 full.
Yesterday I filled both tanks, $90. Crazy
wraprail is offline   Reply With Quote
Old 04-21-2013, 07:37 PM   #7
Zane M
I feel your pain..
I have a '87 V20 and while I do my best to keep it over a quarter(to help with pump life), I do inevitably run it down to 1/8.
PO installed a non-baffled tank on one side and I do have occasions where the truck stumbles or dies on a hard right or left turn, or on an incline when I'm getting low on fuel.
Just some food for thought
