Just got my LS rad check it out
Just got my LS rad check it out, should fit just have to get 4 row mounts and maybe small mod.
Re: Just got my LS rad check it out
Nice looking set up.
Where's it from? Kim |
Got it from summit it's a Griffin rad, Came with relays and temp sensor for head.
http://www.summitracing.com/parts/gri-cu-70013-ls |
I like that. Even better Griffin is made in the USA. Thanks for sharing that.
#5 | |
Posted via Mobile Device |
What rad hoses are you planning to use. Same with trans lines. I'm at the same cross roads determining which rad to buy and hoses/lines to connect everything.
JRods Garage
Such a great price! I just added it to my wish list on summit... LOL
Plan on using these hoses, Summit part Numbers bottom hose GTR-60374 top hose GTR-61331. Not sure about trans lines.
![]() Join Date: Feb 2009
Was it complete with the shroud and fans, too? I was leaning toward using my stock radiator and shroud, but may go this route for the price.
1970 2WD K5 1968 Camaro Conv 1967 Chevy SWB 1964 Malibu SS 1957 Corvette Pics www.picturetrail.com/wesmigletz |
#10 | |
That's pretty sweet. I may have to order one.
JRods Garage
![]() Join Date: Mar 2011
Is this part number GRI-CU-70013-LS from Summit? I'm hoping so, because that is what I have ordered and it's scheduled to be delivered today! Looks sweet from your pictures.
Edit: Nevermind, I saw where you listed the part number above, and I just missed it. I didn't understand how they have things priced either, but I'm glad it worked out well. Last edited by shearjs; 04-23-2013 at 02:08 PM. Reason: Overlooked some info already posted. |
![]() Join Date: Apr 2005
Looks like a great deal. Can you post pictures of how it mounts once you get the new 4 Core hold downs? Thanks
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 |
#15 |
That part is way more money now!
#16 |
Wow, slight change in price. I'm sure glad I got my order in when I did!
#17 |
Just out of curiosity, what was the original price?
1972 C20 Suburban- Big Blue Betty '56 Chevy Bel Air Sedan- Frame up Restoration -What would you attempt to achieve if you knew you could not fail?- -I Refuse To Tiptoe Through Life, Only To Arrive Safely At Death's Door- R.I.P. EAST SIDE LOW LIFE |
#18 |
Parts Total: $459.95
Additional Shipping Charge $55.00 Delivery and Handling Charge $12.95 Total Charges: $527.90 Posted via Mobile Device |
#19 |
Have you tried mocking up with 4 row radiator mounts yet? I have some headed this way, but they haven't came in yet. Just curious of the fitment.
#20 |
I recently checked with Entropy Radiator and they make a similar setup. They didn't have my '57 Chevy pickup listed so I emailed them. They do make one for my application and the cool part is they will set it up for a LS motor with the inlet, outlet, and transmission cooler connections in the right size and placement. The pricing was similar.
#21 |
Any updates on the fit? Any modifications required on the radiator support? Looking to purchase a unit but getting info is hard. Any help.
............................................................ 68 Chevy CST SWB w/LS1, carb & 700r4. Golden Anniversary clone with a few improvements. |
#22 |
Just got my frame back from the body shop this week. It's been slow going Because I Work out off town and Won't be back at it for another 3 weeks, I'll post some pics as soon as i get it together.
#23 |
Got mine installed last weekend using the 4 row mounts. Just some slight trimming on the rubber bushings and a quarter inch spacer under the top mounts.
#24 |
I like it Jason. So the bottom fit in okay, or some trim needed?
Is that the steam line beneath the upper hose? |
#25 |
I replaced the bottom retainers/rubbers with the 4row as well, and had to trim the rubber pieces a little on both the bottom and top. You're correct, that is the steam line below the upper hose.
