04-21-2013, 02:58 PM | #1 |
4 core radiator retainers
Well after some investigation I have found that the radiator that was in my truck appears to be from a 70ish Chevelle. Last week I ordered a new 3 core radiator which was marked for a C10, but after further research it too was for a Chevelle. My problem is with the retainers that bolt to the core support. The tank on the drivers side will accept the standard 3 core mount. The tank on the passenger side is nearly 1" wider and the previous owner made cuts in the 3 core mount to make it fit also pictured below. I'm asking someone to measure the rubber mount area for me and possibly snap a picture to see if I can order a 4 core retainer for the passenger side.
Thanks! Stock retainers, the bottom one has the cuts Old radiator, you can see the difference in end tank thickness Measured the thickness of the driver side tank on the new radiator And the thickness on the passenger side Posted via Mobile Device |
04-21-2013, 06:14 PM | #2 |
Re: 4 core radiator retainers
There is almost an inch difference between the 2-3 core and 4 core mounts
62 Willys 4wd Pickup : 72 C-10 swb 504 stroker 09 Taco 3" lift 33" tires: 90 K-5 blazer (plow truck): RIP Ross Little brother |
04-21-2013, 06:27 PM | #3 | ||
"I ain't nobody, dork."
Order the correct ones from Wes at Clkassic Heartbeat. It's where I got my 4 core rad retainers. They were original GM, and came in NOS packaging. I was quite suprised to see that.
Gary
04-21-2013, 06:41 PM | #4 |
Thanks vidman that was exactly what I was looking for. Looks like I need 4 core mounts for the passenger side.
04-21-2013, 07:12 PM | #5 |
Your Welcome and good luck..
04-21-2013, 09:02 PM | #6 |
Great pics vidman.
Was after some info regarding the differences between radiator mounts. Your pics with a measuring tape for clarification were exactly what I needed. Nicely done sir. |
04-21-2013, 09:02 PM | #7 |
I am a Referee of life.
^This one^ Take measurements of the new radiator have them handy so he can help you match up on the first try.
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion. You can't fix stupid,not even with duct tape. "My appearance is due to the fact that "GOD" does punish you for having too much fun!" Barrett-Jackson has perfected alchemy,they make rust into gold! "You can lead a horse to water but you can't saddle a duck" "Cleverly disguised as a 'Responsible Adult' "Sometimes your Knight in shining armor is just a retard in tinfoil" |
