Closed Thread
Old 04-23-2013, 01:46 AM   #7526
Blue_Aura
Blue_Aura's Avatar
Re: What did you do to your truck today?
Originally Posted by rideblue00 View Post
put on some new s/s brake lines!
Very nice. Did you make your own lines or were they Pre-made? If Pre-made, where did you get them?
Current Vehicles:
'62 C10 - 350 (current project), '03 Tahoe (C Series)
Some Past Projects:
'69 Nova - 350 , '70 1/2 Camaro Z28 - LT1 350, '73 K20 Full-time 4x4 - 400 SB, '77 1/2 Camaro Z28 - 350, '84 Camaro Z28 - 305, '68 Buick - 430 BB
Blue_Aura is offline
Old 04-23-2013, 01:53 AM   #7527
Blue_Aura
Blue_Aura's Avatar
Did a little mock-up to try and decide what color to paint the intake manifold. Spent hours cleaning and wire brushing, then painting... Only to realize that I torqued down the heads without using non-hardening sealer! Going to fix that on Saturday and paint some more pieces.
The air cleaner will match the final blue color on the engine. Those are temp v/c the ones going on it are Mickey Thompsons and will have the flutes and the M/T in the same color blue.
Current Vehicles:
Some Past Projects:
Old 04-23-2013, 02:24 AM   #7528
donthekawguy
donthekawguy's Avatar
Didn't do anything to my truck but I did get my compressor hooked up so I can do stuff for my truck. I had the wires hooked up wrong in the plug I put together but got it figured out. It's in my laundry room so I only had to build an 8 foot long cord for it. Being single has it's advantages.
66 shorty
donthekawguy is offline
Old 04-23-2013, 08:43 AM   #7529
robber grin
lowslow64 - I think I'm in love with your truck...
joedoh - can't stop looking at your truck - s w e e t with attitude...
rideblueCO - very nice bit of work on those lines - please come do mine.
Snowbound - did you try some rubbing alcohol to get the "rubber" parts to slip around better for you? It should flash dry fairly fast without residue.
Liv'n the dream - rg
robber grin is offline
Old 04-23-2013, 04:23 PM   #7530
MikeS.
MikeS.'s Avatar
Got the front LED turn signals installed and working on the MH.
Past Master
Triluminar Lodge #117 GL of WVa
My 1963 4x4 Suburban build;
http://67-72chevytrucks.com/vboard/s...d.php?t=531274
My Gallery, now with pics of my 1966 C30 motorhome.
http://67-72chevytrucks.com/gallery/...&ppuser=103447
MikeS. is offline
Old 04-23-2013, 06:46 PM   #7531
MikeS.
MikeS.'s Avatar
Busy Beaver today. On the left headlight the top adjustment screw was broken. Actually the plastic piece the screw screws into was broken. I had ordered 4 new ones from LMC they came today. So I got the tools back out and replaced them. It was actually easier than I thought it would be.
I should've ordered new springs for the headlights I didn't think to so next time I put together an order I'll try to remember and order new springs.
Now I need to find a shop that can adjust them properly. I'll do the old shade tree trick tonight using the garage door.
Past Master
MikeS. is offline
Old 04-24-2013, 12:06 PM   #7532
bobbylast
bobbylast's Avatar
Been at it for a while now but it's slow moving with kids and wife work and home life, but I've managed to get a couple of things underway....
If you used to be...then i guess you never were.
bobbylast is offline
Old 04-24-2013, 12:08 PM   #7533
SCHRUMGMC
SCHRUMGMC's Avatar
Broke my neck looking at that Photo
Waiting on that guy, to tell me a Price on my Truck
I hope its not outrageous
1971 GMC Sierra
1959 GMC 100
SCHRUMGMC is offline
Old 04-24-2013, 12:10 PM   #7534
bobbylast
bobbylast's Avatar
BWaiting on that guy, to tell me a Price on my Truck
Can't figure out why they're flipping when I upload they're normal but they post upside down. Maybe something o do with the ipad
Old 04-24-2013, 12:15 PM   #7535
jbgroby
jbgroby's Avatar
Damn, Talk about some good tires, great traction!
jbgroby is offline
Old 04-24-2013, 04:07 PM   #7536
kieth
kieth's Avatar
Years ago I was putting a 220volt air compressor in my garage, just behind where I needed the electrical plug was a wall that ran perpendicular and there was a 220 plug for a dryer. Since we had a gas dryer it was not used. So I drilled a hole into the garage wall and then through the perpendicular studs to the box where power was inside the utility room. fished the wires, set the new box in the garage, put a blank cover on the outlet box in the utility room. Just as I was getting ready to turn the power back on, my wife flushed the upstairs toilet........water gushed out from under the wall in the utility room,,,,,,,,I had drilled through the PVC drain pipe for the upstairs bathroom. You should have seen it, when I cut out the hole to fix the pipe the wiring went right through the PVc pipe via the 2 holes I had drilled in it, and of course it leaked. Never did live that one down. Your reference to a 8' extension cord made me think of this. Kieth
kieth is offline
Old 04-24-2013, 06:00 PM   #7537
rideblue00
rideblue00's Avatar
wowee there bobbylast.... what happens when you lose that 9/16 wrench?? must be heck trying to find it!!
I made a fixture to stretch my hood springs so i could powder coat them
rideblue00 is offline
Old 04-24-2013, 11:07 PM   #7538
donthekawguy
I got my rear end blasted and coated with rust treater, replaced one seal so far and screwed up a spring holder on a backing plate. Good thing I have my old rear end to get parts off of. I wish I would have figured out what the gear ratio is before I took it apart I'm dying to know. Oh well I can wait till tomorrow. I need to take the brake parts off my other rear end, clean up all the springs and stuff, change the other seal, paint it with por15 and I think thats it. I'm still waiting for my trailing arms and wiring harness then I can get it all together.
66 shorty
Old 04-25-2013, 12:37 AM   #7539
1966FLEETSIDE
1966FLEETSIDE's Avatar
Adjusted idle on carb,was ideling too high,lowered it just a tad,it purrrrs like a big cat now.
1966FLEETSIDE is offline
Old 04-25-2013, 10:16 PM   #7540
dantimdad
dantimdad's Avatar
Well, I went and looked at the ultimate add on for my truck... A 5 bay garage with a paint booth and a sandblasting booth!
If the guy agrees on the price I may be stopping work on the truck and the falcon and moving them to the shop after I do some cleanup work, repair the huge compressor and run lines, add more lighting and paint the place. I think the other smart thing to do would be to go ahead and buy the 65 1 ton truck I looked at last week, and turn it into a car hauler.
I plan on renting out booth time and bay time to help cover the payments, which by the way, would be so cheap I could actually pay them by picking up sand blasting jobs.
No pics of the place yet. Keep your fingers crossed!
Steven
“Life is and will ever remain an equation incapable of solution, but it contains certain known factors.” - Nikola Tesla
Matt. 6:27 "Who of you by worrying can add a single hour to his life?”
http://www.67-72chevytrucks.com/vboa...=507266&page=2
dantimdad is offline
Old 04-25-2013, 11:03 PM   #7541
donthekawguy
I got a coat of por15 on the new rear end and spent another 400 bucks at classic.
66 shorty
Old 04-26-2013, 12:03 AM   #7542
azdude1964
azdude1964's Avatar
work on my 76 chevy luv.. tryin to get it straight again
efi 496bbc th350 custom brakes narrowed 9 coilover rear.
azdude1964 is offline
Old 04-26-2013, 10:53 AM   #7543
70inline6
Just swapped out my fuel tank sending unit. HEY!!!! My gas gauge works!!! Now to re-gasket that carburetor...
70inline6 is offline
Old 04-26-2013, 11:13 AM   #7544
Rich 5150 69
Rich 5150 69's Avatar
Top right side of axle housing will have a series of letters / numbers, that will denote your axle gear ratio and if it is, or was posi....!
or you can count the pinion tooth count and the ring gear count and divide the pinion into the ring count...
`64 C10 vortec 350/350/373 posi
`69 RS/SS 350/350/308
`37 Ford 406/350/324 traclock
`68 Dart 370/904/323 suregrip
Rich 5150 69 is offline
Old 04-26-2013, 01:45 PM   #7545
Vernski
Put some SS rail caps on Frank, I think he likes these better than the wood racks I concur. I could not find any for 60-66 any where, these are for a 73-80 I just trimmed each end a little...Vernski
Vernski is offline
Old 04-26-2013, 06:39 PM   #7546
MikeS.
MikeS.'s Avatar
Bought a remanufactured PS kit to replace the current leaking parts.
Past Master
MikeS. is offline
Old 04-26-2013, 09:28 PM   #7547
Blue_Aura
Blue_Aura's Avatar
Spent some time at a local muffler shop getting a new cat installed on my civic and talked with the owner of this 56 Bel Air. He has done a lot of them. After he left the shop owner was telling me that the owner of the 56 was complaining about the new exhaust costing $280. The shop owner was running 3" dual galvanized pipe (one whole piece each to the mufflers) to the Summit turbo mufflers (provided by 56 owner), then to chrome tips. You ask me, that was one incredible deal!
Car was a complete frame off and has an IROC engine in it. The front clip was off. The owner trailered it there and I saw that he only had two lugs per tire installed and paint on some tires. Those Cragar stars are his junk rims!
Current Vehicles:
Some Past Projects:
Old 04-26-2013, 09:40 PM   #7548
1963c-10
1963c-10's Avatar
nice project hes working on
1964 Short bed trailer
1963c-10 is offline
Old 04-26-2013, 10:34 PM   #7549
donthekawguy
I have the pin and c clips out right now or I would count the teeth. When I get it buttoned up I'll figure it out. I also want to take the cover off the old rear end and find out what gears the PO put in there. I'm going to guess 4:50 or so plus he welded the spider gears so it's pretty much useless for me.
I finally got my parts from Performance Online so now I can start getting it together. My trailing arms are still at the coaters so thats going to slow me down. Plus I have school 3 days next week and test for my CDL Saturday after working 40 hours this week. I'm hoping to squeeze a few hours in on the truck tomorrow and Tuesday.
66 shorty
Old 04-27-2013, 07:45 PM   #7550
TJ's Chevy
TJ's Chevy's Avatar
I used mine around the farm today. Then took it for a joy ride. Man those old tires scare me somtimes!
TJ's Chevy is offline
Closed Thread
