Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Suspension > Suspension Marketplace
Old 10-24-2012, 07:55 PM   #26
robnolimit
robnolimit's Avatar
Re: No Limit Wide-Ride C10 IFS 63-87
Here are the upper and lower u-joints on a Wide-Ride install on a 70 C10. U-joints are from Flaming River. We used the OE floor mount in this instal, with the factory rubber boot.
GoodGuys 2012 Pro-Truck Champion
2012 Truckin' Throwdown Champion
GoodGuys 2011 National Champion
2011 Truckin' Throwdown Champion
GoodGuys 2010 National Champion
Proud to put our products up against all others!
robnolimit is offline   Reply With Quote
Old 10-24-2012, 07:57 PM   #27
robnolimit
robnolimit's Avatar
An overall shot shows the angles, the top is 28*, and the lower is 15*. A slight notch, approx 1/4" deep, is needed in the frame rail top to help with steering shaft clearance. In other installs, I moved the floor mount position for the column down 1/2", and over (toward the motor) 3/8" from the stock location. This change helps the column to fit the seat better, and adds to steering clearance. We use 30" columns on C10's here. This is a IDIDIT column. I like to use the universal type, not the 'direct fit' columns. If you want a column shift, still use a 30" column. Try a Kugal shift linkage kit for the link to the trans.
Old 10-30-2012, 08:11 PM   #28
68steppsidee
any news
68steppsidee is offline   Reply With Quote
Old 10-31-2012, 11:40 PM   #29
kwin
kwin's Avatar
I've been trying to get in touch with you regarding using your kit on my 1991 Suburban. I'm doing a turbo 6.0 swap and want to make a big change in handling.
Your receptionist has said that you don't recomend this kit for my application and I was wondering why?
I have left me name and numner but no one has called me back.
Can you tell me why I should not use your kit?
Keith
Keith Winsor
www.ramsaywinsor.com
kwin is offline   Reply With Quote
Old 11-01-2012, 01:18 AM   #30
Wasted Income
Boosted Member
Wasted Income's Avatar
Got mine 90% finished up.
In my experience it hasn't been a 100% bolt in deal. Trim some stuff here, cut some stuff there, file these so they fit. I am hoping the steering doesn't end up being a headache, since I was planning to use a stock tilt column.
Gotta say though, if it works half as good as it looks, the tweaks required during installation will be worth it.
1972 2wd K/5 Blazer Turbocharged 370 LSx - 941 rwhp / 1093 rwtq
1969 Chevy K-10 L33 5.3 / 4L80E / NP241 / 4" lift
1964 Buick Skylark Twin TURBO 383 LS pro-touring project
2014 VW Passat TDI - Daily Driver
Turbo diesel
2015 Sierra Denali HD Duramax Turbo diesel
2023 Ford Explorer ST - Twin Turbskis
2023 Ford F150 RCSB - Whipple Supercharged
2017 Polaris RZR Turbo
2014 Nor-Tech Center Console - Twin Supercharged Outboards
TURBO ALL THE THINGS!!
Wasted Income is offline   Reply With Quote
Old 11-01-2012, 11:46 AM   #31
higXtech
higXtech's Avatar
Keith
hey keith - you may have to wait for SEMA to wrap up and then give it a couple days for the backlog to clear out. This is like a holy-week for many of our trusted vendors.
higXtech is offline   Reply With Quote
Old 11-02-2012, 10:50 PM   #32
fatgump
fatgump's Avatar
[QUOTE=Wasted Income;5679081]Got mine 90% finished up.
Gotta say though, if it works half as good as it looks, the tweaks required during installation will be worth it.[/QUOTE
The stock column will not work. You can see in the photos my new CPP column with the three u-joints did not work. I went with a ididit 30" column and flaming river u-joints that I picked up from Scotts, thanks Justin. You are also going to have to mod your trans cross member, shorten your drive shaft, mod your motor mounts and adjust your pinion angle ( with a gen 1 SBC). If you have a low hump cab it will be a tight fit. I will let you know how it performs after the Goodguys show, autocross in Arizona.
fatgump is offline   Reply With Quote
Old 11-04-2012, 06:28 PM   #33
68steppsidee
what if your running a muncie 4 speed... is it gonna afect the z bar and clutch linkage. also what has to be done to the trans crossmember?
Old 11-04-2012, 10:36 PM   #34
fatgump
fatgump's Avatar
I have a th400 and had to move the trans crossmember back and raise it.
Old 11-06-2012, 12:55 PM   #35
robnolimit
robnolimit's Avatar
Gump, you project is looking great. How much did the trans go back, and up? And, was the motor in the 'forward' mounts before? How much clearance from pan to crossmember? And how about the rack?
Old 01-12-2013, 12:54 AM   #36
raydzyn72
how you guys liking the no limit kit? im about to get a frontend kit just up in the air on what to go with. porterbuilt, no limit? wanting a good driving set up on 20"s not tucked
raydzyn72 is offline   Reply With Quote
Old 01-31-2013, 01:05 PM   #37
robnolimit
robnolimit's Avatar
We have been installing our IFS and rear rail kitson a 68. This is a nice, clean truck, and we are using the kits, right out of the box. This makes it the same type of install as can be done in a home shop. For a kicker, we decided NOT to pull the motor and trans, which makes the install a little different, but we had a lot of questions about this, so we're doing it. All of the build is in the project build section, the No Limit BCC build.
Old 01-31-2013, 01:09 PM   #38
robnolimit
robnolimit's Avatar
Start of the rear rail install
Old 01-31-2013, 02:01 PM   #39
kwin
kwin's Avatar
Lol Sema 2013,2014? I give up, I'll find another direction they clearly don't want my business.
Keith Winsor
Old 01-31-2013, 05:11 PM   #40
robnolimit
robnolimit's Avatar
Well, what do you need?
Old 01-31-2013, 07:40 PM   #41
SCOTI
SCOTI's Avatar
Keith
Post #30 above.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 01-31-2013, 08:02 PM   #42
kwin
kwin's Avatar
Keith
Post #30 above.
Well that sums it up! Thanks
Keith Winsor
Old 04-16-2013, 03:09 PM   #43
Wasted Income
Boosted Member
Hey Rob, can you provide the suggested alignment specs for the WideRide on a street driven truck? I'm getting very close to wrapping up my project and getting it aligned.
Turbo diesel
Old 04-23-2013, 11:38 AM   #44
Wasted Income
Boosted Member
Helloooooooooooooooooo??
This would be good info for anybody who purchases this suspension...since this info was missing from the "instructions".
Turbo diesel
Old 04-23-2013, 12:47 PM   #45
higXtech
higXtech's Avatar
dont know if this helps but from the wideride website:
We recommend 1/2 Neg Camber, 3 to 3 1/2" caster and about 1/8" Toe-in
1968 fleetside - nolimit wide ride front and rear + ridetech
Old 04-23-2013, 02:21 PM   #46
Custom 68
Custom 68's Avatar
It will be interesting to see what is recommended, as I have continued to read I would assume about twice that on Caster. One statement on here also recommended toe OUT rather than in. I don't know.
Dave
1968 Custom Chevy with turbo charged 5.3 gen III 4l80e swap
1967-71 GMC 3/4 ton long step 4x4 (not sure what year exactly?)
"A good friend will bail you out of jail...but a true friend will be sitting next to you saying "that was frekin awesome".
"If it doesn't fit force it...If it breaks then it needed to be replaced anyway!"
Custom 68 is online now   Reply With Quote
Old 04-24-2013, 01:52 AM   #47
robnolimit
robnolimit's Avatar
Oooops. sorry sorry sorry. Spring is alway so hectic. Yes, the web site is our base set up. I would prefere 5 or 6 degrees of caster, for a better feel, and as you question, about 1/16" to 1/8" toe out. Toe out can quicken up the turn in, it can also make the truck quicker to react. - not for lazt drivers or texyers. this can put you in the next lane in a hurry. It can also increase mid-corner speeds 5+ mph. thanks for the helpp guys.
Old 04-24-2013, 09:37 AM   #48
Wasted Income
Boosted Member
Thank you Rob.
Hoping to have my junk roadworthy in a week or two....can't wait to try out the wideride.
Turbo diesel
Old 04-24-2013, 10:13 PM   #49
fatgump
fatgump's Avatar
You will be pleased with the way it handles. My truck did good at the Scottsdale Good Guys Autocross in Nov. The driver needs some work.
Old 07-29-2013, 09:58 AM   #50
Dano69c10
Dano69c10's Avatar
Wasted Income, how did this turn out? Anymore pics?
'69 Fleet
It ain't yours, if you didn't build it!
Dano69c10 is offline   Reply With Quote
