Old 04-23-2013, 02:48 AM   #1
jerry73
flywheel comparison
The truck i have is a 1978 chevy with a 1991 Chevy 454 in it. The previous owner swaped in fhe 454 in the place of the factory 6.2l diesel engine.....my question is will the flywheel off the diesel work on the 454,reason for the question is i believe the diesel flywheel is on the 454 and ive sheered teeth of the starter and replaced it twice because it doesn't seem to be lining up
jerry73 is offline   Reply With Quote
Old 04-23-2013, 03:15 AM   #2
andrewmp6
Re: flywheel comparison
If its a auto its a flexplate but look it up on like jegs or summit see how many teeth it should have vs what you have on it.
Old 04-23-2013, 03:28 AM   #3
jerry73
Cant find thw diesel flexplate on there so i cant match them up...my guess would be that its probably the same difference between a small and big block flex plate right?
Old 04-23-2013, 05:06 AM   #4
b454rat
No it won't work. 454 is externally balanced.
2000 GMC CCSB 454/4L80 6” lift SAS
1999 Chevy CCSB 454/NV4500 4” SAS
1999 GMC Yukon 350/4L60 6" SAS
Old 04-23-2013, 01:33 PM   #5
jerry73
Ok thanks...how can i tell which flexplate is on my truck
Old 04-23-2013, 05:25 PM   #6
b454rat
An externally balanced flexplate will have weights welded on the back side of it...
