#6701 |
Re: What did you do to your truck today!
Yesterday, oil change, clean air filter, add 2" blocks in the rear (from Boris) then did about 70 miles of driving and then washed it.
Today added a front anti sway bar, then drove it, these lastest upgrades made a huge difference in driving. A rear sway bar may be on it's wanted list. |
#6702 |
Got me some ten inch rallies.... hehehe
![]() ![]() And primered...will be RED with chrome center and beauty rings... ![]() |
#6703 |
Fixed the headlight/dimmer switch. Tomorrow the Tachometer and fuel gauge.
#6704 |
![]() Join Date: Jan 2010
Got the new starter and aux. solenoid installed on the panel truck.
#6705 |
RAT1968 '68 Cab/'71 Parts
Made this out of stuff from around the house. It's gonna ger a piano hinge and some magnetic "keep it closed" and a hidden "opener".
I made it to house a bucks-up Pioneer electronics set up that used to be mine and my friend is giving back. DVD player, Nav, etc. I'll also punch holes in the "door" for a white faced clock and a manifold vacuum gauge, I think. Not sure if I'll do it or not, but I'm also always looking for a smart place for Mr. Smith to ride. ![]() I HATE digging around with a spagetti dinner of wiring in close quarters.. So, I'll be able to open the door and get at everything.
M17 Coarsegold, CA RAT's shiny now. But always a rat. Last edited by magwakeenercew2jh; 04-23-2013 at 12:17 AM. |
#6706 |
![]() Join Date: Dec 2012
Went to go look at the truck, talked about a price
1971 GMC Sierra 1959 GMC 100 |
#6707 |
![]() Join Date: Feb 2012
I primed my inner fender wells front and rear, radiator support, bed cross braces. I am borrowing my old 72 tomorrow and going on an 8 hour cruise to pick up new bed sides and tail gate. Paint is real close
#6708 |
I got a factory looking tachometer installed, took it for a test drive, and filmed it for you
http://youtu.be/oRZNwEmaBy8 Posted via Mobile Device |
#6709 |
___________________________________ Dima 1970 Chevrolet C10 stepside http://67-72chevytrucks.com/vboard/s...d.php?t=569197 |
#6710 | |
But I now know how twisted you are after watching the Christmas prank ![]() Posted via Mobile Device
1971 Chevrolet C10 Inflation Fighter ![]() 1994 C3500 Crew Cab Dually 454
#6711 |
Getting closer every day......................just finished up with a little sanding & buffing. Have lots of little things to complete, but wont be long now.
#6712 |
#6713 |
Installed my new steering wheel
68 c20 build: http://67-72chevytrucks.com/vboard/s...d.php?t=358130 Club longbed ...cause girls like'em long!!!!! |
#6714 |
![]() Join Date: Jan 2012
Are those rally rims? What size are the back ones and did you have to narrow the frame?
Matt Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=672655 "Father thank you for the gathering of friends, Father we give thanks for all the choices we've made because that's what makes us who we are, let us forever cherish the loved ones we've lost along the way and most of all THANK YOU FOR FAST CARS!" |
#6715 |
![]() Join Date: Aug 2011
Finally got my rally's installed after powered coating and a new set of AT/KO's
#6716 |
#6717 | |
![]() / Patrik Posted via Mobile Device
C20 4x4 1970 TBI350/TH350/NP205 Sweden |
#6718 |
Thanks Patrik, I have owned the truck for a couple years and I have been trying to change over to the rally's since i brought it. When I purchased the truck it had a set of 17 X 8 Helo's with 285's, now rally's with 33 X 10.50 BFG's.
#6719 |
Yes they are rally's & no I did not narrow frame. I made the back wheels from 15 x 15 blanks from speedway & the centers from a set donor rally wheels. New wheel blanks have no provisions for trim rings, so I made up a set of fake bead locks, welded them to rims so I could mount mirrored SST trim rings to. Rear end is a Dana 60 I narrowed & then hung with my own triangulated 4 link & coil overs.
#6720 |
Put fresh rubber on the rally wheels.
#6721 |
Just got down installing a 6.2 diesel into my truck.
Kerry My build thread. http://67-72chevytrucks.com/vboard/s....php?p=3657823 1971 Chev SWB with 68 nose, 6.2 diesel th350, and 3.73 rear gears 1988 Chev Extendacab 2010 Honda VT1300CS Sabre 2005 Buick Rendezvous wife's ride |
#6722 |
Coming down to the final wire. Bleeding the brakes, picking up the drive shaft tomorrow, sending to the exhaust shop early next week and test fitting the 20" wheels. Should be on the streets of Colorado within the next few weeks, just in time for summer.
Build: http://67-72chevytrucks.com/vboard/s...d.php?t=541803 Dennis H 1969 Chevy C10, SWB, LS3,6.2L engine 1969 Chevy Chevelle SS,BBC, Convertible |
#6723 |
![]() Join Date: Feb 2007
Blew my motor up
Steve 1971 GMC Longbox. Full Roller Stroker 489 w/ FiTech EFI, Chris Straub Cam/NV4500/205/D60/14B w. Grizzly Locker and 4.11's. 2" Lift on 33's |
#6724 |
Old member
WWW.SpeedHut.com sent my gauge back, got it today but the left the program wire out. Had to call them back. They are over nighting me the cable. Man I want to drive the truck.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 ![]() Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. |
#6725 |
M17 Coarsegold, CA RAT's shiny now. But always a rat. |
