Old 04-23-2013, 09:17 PM   #1
vortech71chevy
'71 SWB frame under a '65?
Hey guys, I am wondering- what would it take to bolt a 65 body onto a good 71 C10 2wd frame that I have? I redid the brakes and would like to utilize the suspension and running gear on my 65 and cut down the bed to make a 65 2wd shortbed, and instead of cutting the frame and bed and bolting all the suspension stuff to my 65 frame... would the body swap be easier? I also have some sweet centerline wheels for the 5x5 pattern. Thanks in advance for any and all help guys, I appreciate it and love the site.
vortech71chevy is offline   Reply With Quote
Old 04-24-2013, 07:58 AM   #2
b.sharp
b.sharp's Avatar
Re: '71 SWB frame under a '65?
I know the front frame is different from the steering box forward and the back cab mounts are wrong for a 60-66 truck. You would have to cut your frame and put on the '71 and put your rear cab mounts on it as well. There may be other small differences but those two are for sure different.
b.sharp is offline   Reply With Quote
Old 04-24-2013, 12:53 PM   #3
aspiringthomas
aspiringthomas's Avatar
Would it be easier to do the Front Crossmember/Rearend swap from the 71.
aspiringthomas is offline   Reply With Quote
Old 04-24-2013, 02:07 PM   #4
Fattback
Fattback's Avatar
I have a 1972 long bed frame i have been working on and was wondering basically the same thing. 63-65 body on my frame. Anyone have pics or links to threads.
Vortech thanks fro starting this thread was just getting ready too
Rob
Fattback is offline   Reply With Quote
Old 04-25-2013, 09:47 AM   #5
Fattback
Fattback's Avatar
Surely someone has done this before?
Any help would be greatly appreciated.
Rob
Old 04-25-2013, 10:32 AM   #6
padresag
a lot easier to just put the axles under your orig frame. you also have no hassles with your ser #
ron
padresag is offline   Reply With Quote
Old 04-25-2013, 06:30 PM   #7
SCOTI
SCOTI's Avatar
Core support mounts @ diff height & fore/aft location (close, but different).
Frame rails diff shape/height @ front bumper.
Rear cab mounts higher for pre-67 cabs (spacer could be made to compensate).
Some bed bolt holes are different.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 04-26-2013, 08:19 AM   #8
Matty Wagz
Matty Wagz's Avatar
I am in the process of putting everything from a 71 under my 66; keeping original frame and bolting everything on...
check out my build thread/ elbow deep in my 66....
WAGZ
Life's journey is not to arrive at the grave safely in a well preserved body, but rather to skid in sideways, totally used up and worn out, shouting '...man, what a ride!' GC
Matty Wagz is offline   Reply With Quote
