Old 04-23-2013, 11:40 PM   #1
bugmasta
bugmasta's Avatar
Emblem installation
So I failed to install the side fender emblem before reassembly and now realized that you can not access the back side of the fender to set the nuts on the emblem. I really do not want to completely disasemble the truck to put the emblem on.
Have any of you guys found an alternative to using the nuts on the back side. I know they have emblem glue out there but concerned about it holding up over time. Any suggestions?
68 c20 build: http://67-72chevytrucks.com/vboard/s...d.php?t=358130
Club longbed ...cause girls like'em long!!!!!
bugmasta is offline   Reply With Quote
Old 04-23-2013, 11:43 PM   #2
leddzepp
Moderator
leddzepp's Avatar
Re: Emblem installation
If you have a gear wrench you can get the nuts on the emblem without removing the fender
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed.
1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck.
RIP ElJay
RIP 67ChevyRedneck
RIP Grumpy Old Man
RIP FleetsidePaul
Old 04-23-2013, 11:45 PM   #3
Mister-B
How so?
Mister-B is offline   Reply With Quote
Old 04-24-2013, 12:07 AM   #4
bugmasta
bugmasta's Avatar
Please tell me more. I see no physical way of getting anything up there.
Old 04-24-2013, 01:35 AM   #5
WIDESIDE72
WIDESIDE72's Avatar
Take the bottom fender bolt off and you can squeeze your arm in from the bottom. I forgot to put them on my dad's GMC. You will never forget again!
WIDESIDE72 is offline   Reply With Quote
Old 04-24-2013, 02:24 AM   #6
SS Tim
SS Tim's Avatar
Resist the urge to use tape or barrel nuts for a front mount solution. A gear wrench will get up in there. Mine are long professional size but a taped extension will allow you to get into surprising places. The key is holding the nut. Electrical tape as a shim to fit tight into the wrench works well as does body caulk or weatherstrip adhesive.
SS Tim is offline   Reply With Quote
Old 04-24-2013, 02:51 AM   #7
leddzepp
Moderator
leddzepp's Avatar
Thank you for elaborating Tim. If you don't have a set of gear wrenches, the electrical tape method works great. Takes a little patience, but it is well worth the effort. Taking just the bottom bolt off as wideside describes will also help you get in there.
RIP ElJay
RIP 67ChevyRedneck
RIP Grumpy Old Man
RIP FleetsidePaul
Old 04-24-2013, 07:28 AM   #8
FirstOwner69
FirstOwner69's Avatar
This is very helpful, and I apologize for the hijacking the thread, but...
I screwed (no pun intended) up and forgot to install the lower molding pieces behind the doors on the cab. The right side is obviously no problem. But, does anyone have a way to install the left molding in a bucket seat truck with the carpet tank cover without moving (removing?) the tank? There's only about 3/8" between the tank and the door pillar.
Jim
FirstOwner69 is offline   Reply With Quote
Old 04-24-2013, 09:04 AM   #9
C5Phil
C5Phil's Avatar
Second that!!! been there....
C5Phil is offline   Reply With Quote
Old 04-24-2013, 09:47 AM   #10
Mister-B
When you say "take the bottom fender bolt off", don't you mean bolts? In other words, you have to drop the whole fender to gain access?
I dropped my fender once when I installed my heater core. What a pain. The bolts were all rusted on, and the nuts back behind would often times just sit there and spin
Old 04-24-2013, 09:56 AM   #11
69GWC
My truck did not have the C/10 or 350 emblems on the fenders so i installed them on it, I pulled the inner fenders out to gain access to the nuts it was tight but i got them on.
69GWC is offline   Reply With Quote
Old 04-24-2013, 10:00 AM   #12
71K20chevy
71K20chevy's Avatar
I was faced with this challenge once...
It was so much easier with the inner fender out (which I conveniently had out at the time). I used a Craftsman 3/8" wrench that was really long. The tough part is trying to get the nuts to thread on!
71 K20
64 GMC mud truck
71K20chevy is offline   Reply With Quote
Old 04-24-2013, 10:56 AM   #13
bugmasta
bugmasta's Avatar
Grrrr, this is what I was afraid of. Don't have any gear wrenches so I will have to try and sneak my arm up there some how. Thanks guys!
Old 04-24-2013, 01:03 PM   #14
Mister-B
Well, and good luck with that if you've got larger than average arms like I do lol. You may want to make a trip to Harbor Freight and get something inexpensive
Old 04-24-2013, 04:03 PM   #15
ChevyNewb
ChevyNewb's Avatar
lol, sounds like me and my sons build. we got rushed and ended up using body glue. it has held for about 6 months. We are now going back and gonna do it right, i have rehabbed some extra emblems. We will be removing the fender as I need to install a new heater core and new door hinges, so it is a perfect time to get this done (on the passenger side anyway)
I would recommend just doing it right the first time
'68 Longbed Stepper. Mango Tango
ChevyNewb is offline   Reply With Quote
Old 04-27-2013, 03:34 PM   #16
bugmasta
bugmasta's Avatar
Got it done. Pain in the ass, but got it done.
Old 04-27-2013, 04:09 PM   #17
bruceman1968
bruceman1968's Avatar
Looks great! good job doing it right. I still have to do this to mine.
CHEVY/GMC VIN DECODERS
bruceman1968 is offline   Reply With Quote
Old 04-28-2013, 06:46 AM   #18
Square_78
Square_78's Avatar
Use silicone. It will never fall off. Stays flexible and it's strong. Forget clips and drilling holes. There was no way I was gonna drill all those holes in my body to install all my trim, moldings and emblems. There are holes in the fenders for the gmc emblems but I used silicone and no nuts on the back. There is no way they are coming off without a pry bar. Plus it seals the existing holes so they won't rust. The silicone will hold forever. Just be careful how much you use on trim pieces. Too much silicone and they will be impossible to remove without destroying them.
#teamlongbed
"I refuse to go disc brakes. I actually love drum brakes. It makes for an adventure." - 50bomb
1978 Chevy shop truck - static 6/8"
1970 GMC 1500 - Accuair eLevel Resto-mod http://67-72chevytrucks.com/vboard/s...d.php?t=537497
Square_78 is offline   Reply With Quote
