Old 04-26-2013, 10:11 AM   #1201
68Timber
I know the pieces fit
68Timber's Avatar
Re: Slosh Tubz new company project "Square Peg" frame laying 1987 GMC Jimmy
Slick, slick slick - even the f'up repairs look good!
John
79 2wd Blazer (Bruiser)
85 M1009 Blazer (Sarge) build
74 Honda Z50 build
Old 04-26-2013, 10:15 AM   #1202
67cheby
67cheby
67cheby's Avatar
LOL, thanks man, stinks to have to re-do something like that but oh well It's just metal ! Now to figure out how to drill my hole for the bar and keep it straight through all 4 layers ! anyone have any tips on that ?
67cheby is offline   Reply With Quote
Old 04-26-2013, 10:37 AM   #1203
jkeating1
jkeating1's Avatar
IDK, but when we were installing fireplaces, and wanted to locate where the chimney was going to be on the roof, we leveled up a .38 pointing straight up in the center of the fireplace and pulled the trigger! Not my recommendation for your application however.
I think I'd employ a laser somehow.
JK
jkeating1 is offline   Reply With Quote
Old 04-26-2013, 10:44 AM   #1204
67cheby
67cheby
67cheby's Avatar
LOL.....yep, don't think I will try that approach !
Old 04-26-2013, 12:40 PM   #1205
LOW1TON
Use a magnetic drill press mounted to side of frame. Drill thru two layers on one side. Then make a template or use a laser to mark other side and use drill press again on the other side.
"WIDER IS BETTER" (TRUCKS ONLY)
LOW1TON is offline   Reply With Quote
Old 04-26-2013, 02:41 PM   #1206
watahyahknow
watahyahknow's Avatar
think the drill press to keep it straight on through the first holes and use that hole to center the laser (maibe a gunsight calibraion laser ?) and centerpunch it on the laserpoint acros on the other side and use the drillpress again but from the inside out
either that or level the frame and make some sort of guide rail under where you need youre holes thats exactly level and at a 45 degree angle to the frame where you can mount the drill on doing it that way you can drill the holes from all 4 sides but it prolly takes a lot of time to make and set up
i got a job again and having fun at it too
idea's for the trucks and the order of things to do are taking shape and get closer to being realized , a few more months and i be able to start building for real
i complete 2 of the trucks intoo running fashion one custom and one basicly stock the thirth will be sacrificed for parts
watahyahknow is offline   Reply With Quote
Old 04-26-2013, 02:42 PM   #1207
jkeating1
jkeating1's Avatar
That, or drill the two inner holes, then figure out a way to project a straight line from those two to the inside of the outer wall on one side; then do the same thing on the outer wall on the other side.
No matter how you do it, I'd use a small bit, because in the end, you'll end up reaming it to make all 4 line up!
JK
Old 04-26-2013, 02:56 PM   #1208
67cheby
67cheby
67cheby's Avatar
yep, pretty tough to figure out the best route !
Old 04-26-2013, 03:29 PM   #1209
jlsanborn
jlsanborn's Avatar
Yup, mag-drill and a Hougen rotabroach. I would think that after you got one side done you could run your bar or a pipe through there, get it straight and locate the other hole. Isn't it just a clearance hole or does it support the bar?
'77 K30 3+3 - "The Crummy"
http://67-72chevytrucks.com/vboard/s...d.php?t=640134
'67 C10 L/SWB - Soon to be daily driver!
http://67-72chevytrucks.com/vboard/s...d.php?t=471776
jlsanborn is offline   Reply With Quote
Old 04-26-2013, 03:53 PM   #1210
67cheby
67cheby
67cheby's Avatar
just in time to get the body mocked up , Energy Suspension comes through with some new bushings !
Old 04-26-2013, 07:13 PM   #1211
Rusbuilt
Rusbuilt's Avatar
Sweet!
Rusbuilt is offline   Reply With Quote
Old 04-26-2013, 08:20 PM   #1212
ryanroo
ryanroo's Avatar
here is an idea that is pretty easy, and ends up looking pretty good as well
here is the other side mounting the skidplate thingy
i did this on my jeep to mount the trans/transfer skid. you make a fishplate with the hole size you need exactly and use a plasma or whole saw to make the holes in the frame close to what you need. then you can adjust the plates in the hole to get everything located exactly where it needs to go. i actually drilled the frame to the exact size for the sleeves but it would have been just as good to oversize the holes in the frame and adjust with the fishplates
Ryan
72 K20 12v build
72 K20 "parts truck"
ryanroo is offline   Reply With Quote
Old 04-26-2013, 09:03 PM   #1213
67cheby
67cheby
67cheby's Avatar
Great idea !
Old 04-26-2013, 09:08 PM   #1214
watahyahknow
he could do that if he cant alighn the holes , he just needs to drill them out and make fishplates
thought of a cheaper idea to the laserpointer : drill the first side put a verry good fitting 4 foot long pipe trough it to the other side sit the frame up side ways and drop a piece of heavy and good fitting roundbar with a point machined on it down the pipe , it should leave a pretty exact crater/divet for the other side to center the drill on
Old 04-27-2013, 01:34 PM   #1215
ddubbs
ddubbs's Avatar
Coming along sweet. Congrats on the parts haul.
LIFTED OR LOW THE ONLY WAY TO GO!!!!
Check out my build thread:
http://67-72chevytrucks.com/vboard/s...d.php?t=517346
Projects
56 Chevy pickup Porterbuilt FR/RR dropmembers
ddubbs is offline   Reply With Quote
Old 04-28-2013, 11:35 PM   #1216
Dinos63
chevy only
Dinos63's Avatar
cool stuff!
CHEVY ONLY... Nothin Else !
Dinos63 is offline   Reply With Quote
Old 04-29-2013, 09:27 AM   #1217
67cheby
67cheby
67cheby's Avatar
thanks guys ! OK finally back on track , fixed my screw up , frame is on the ground ! Motor going in tonight ! What redneck doesn't do mockup with Studded snow tires ????? LOL, that's just how we roll !
Old 04-29-2013, 09:37 AM   #1218
Rusbuilt
Rusbuilt's Avatar
Very nice sir!
Old 04-29-2013, 09:49 AM   #1219
77ChevySharkBite
77ChevySharkBite's Avatar
It's beautiful!!! The craftsmanship on "Sqaure Peg" is just mouth dropping!
Korwin
77 C10 Silverado Sharkbite LWB Build
67 Chevy C10 Frame Off
06 Dodge Magnum 2.7v6 aka swag wag!
2010 Honda Accord 2.4I4 DD aka Liquid Metal
77ChevySharkBite is offline   Reply With Quote
Old 04-29-2013, 09:59 AM   #1220
67cheby
67cheby
67cheby's Avatar
thanks guys, I appreciate that !
Old 04-29-2013, 10:14 AM   #1221
BigDaddyV
BigDaddyV's Avatar
/bows to the master. All Hail the Man (with his snow shoe mock up....) lol
Looking great bud! Cant wait to see the Square rollin.
J. Vess, 6'6", Gearhead, Welder, Fabricator, Nutcase
1955 Chevy Stepside "Dudley"
My daily http://www.67-72chevytrucks.com/vboa...d.php?t=760288
1972 Chevy C10, Project "Chevro~Layed out" Nether Storm
Build Thread http://67-72chevytrucks.com/vboard/s...23#post6007523
BigDaddyV is offline   Reply With Quote
Old 04-29-2013, 10:22 AM   #1222
oldman3
oldman3's Avatar
Looks sweeeet...Jim
oldman3 is offline   Reply With Quote
Old 04-29-2013, 10:39 AM   #1223
67cheby
67cheby
67cheby's Avatar
LOL, yea that was great ! Thanks !
Originally Posted by oldman3 View Post
Looks sweeeet...Jim
thanks Jim
Old 04-29-2013, 11:29 AM   #1224
Low Elco
Snow tires. Awesome. Looks terrific! Off to Oklahoma?
Low Elco is offline   Reply With Quote
Old 04-29-2013, 02:44 PM   #1225
thor
thor's Avatar
Your comment about using studded tires for mock-up reminded me of this article about building your own ice racing tires...
http://www.jpmagazine.com/featuredve.../photo_02.html
Maybe the next build?
1972 Chevy Blazer CST.....Project: Polished Turd
thor is offline   Reply With Quote
