Old 04-06-2013, 11:29 AM   #26
starterman99
starterman99's Avatar
Re: Aftermarket Underbed Fuel Tank Filler Neck/Cap Options
Heres a picture showing how close tank and filler are.You can see theres not much space to work with.
1950 5 window
starterman99 is offline   Reply With Quote
Old 04-06-2013, 03:23 PM   #27
Denee007
Denee007's Avatar
Gee Starterman, good picture! I'm kind of wondering how one gets the hole to fit the filler neck as your pic shows! I was thinking to buy a 1x4x however long to make a template? It'll be a while before I do this, but your pic really helps!
Dne'
'72 Ford Bronco project(July 17 2021-?)
https://67-72chevytrucks.com/vboard/...d.php?t=828015
59 Apache (sold 6-25-2021)
67 Ford Mustang (re-restored after Harvey)
1968 Jeep Cj5 (2-8-2020 to present)
1992 Jeep Yj (8-17-20 to present) (Jurassic build)
www.Classiccarsandtools.com
Denee007 is offline   Reply With Quote
Old 04-06-2013, 10:48 PM   #28
lowrodderchev
lowrodderchev's Avatar
Originally Posted by Daze57 View Post
imho i think dan has a good idea cut what ya dont need off and use a rubber sleeve and clamps - have seen it b4 and seems to work out well
good luck !
I have the same filler did this to cut it down but I used a mustang tank
lowrodderchev is offline   Reply With Quote
Old 04-07-2013, 07:34 PM   #29
NW Task Force
NW Task Force's Avatar
Starterman99,
Wow! Thanks for the great under bed photos! I will probably go with this method. I will document the process and post pics of the results. I know other folks are wanting to see more and get inspired.
1957 Chevy Pickup 1/2T, stepside, big window, 77' Camaro subframe, 3rd gen Firebird rearend w/3.23 gears & disc brakes, 66' 283cid, TH350 auto, everything else is original
NW Task Force is offline   Reply With Quote
Old 04-14-2013, 04:45 AM   #30
bobinbc
bobinbc's Avatar
LOwrodderchev, I sure would like to see how you adapted that mustang tank neck to the filler neck, I'm using the mustang tank too. It comes up on a bit of an angle, did you just join the two with a piece of hose ?
1962 Chevy blue SBFS
1957 Chevy yellow SBSS
1956 GMC red SBSS Nov 2017 ToTM
https://www.facebook.com/groups/Cana...geChevyTrucks/
bobinbc is offline   Reply With Quote
Old 04-26-2013, 12:56 AM   #31
NW Task Force
Starterman99.............are you out there?
This question is for Starterman99........... what are you using for a gas tank vent? (tubing size, fittings, etc?) I am looking at my options on what to do for my tank vent. Thanks!
Old 04-26-2013, 09:40 AM   #32
Nordic
Nordic's Avatar
I have the same type set-up, I used a length of 3/8 fuel line with a breather from a differential, tied up along the frame so it is as high as possible.
Nordic is offline   Reply With Quote
Old 04-26-2013, 11:11 AM   #33
starterman99
Re: Starterman99.............are you out there?
I basicly did the same as was just stated.3/8 fuel hose ran from top of tank over top of frame and secured to fender bolt.
1950 5 window
Old 04-26-2013, 11:50 AM   #34
mknittle
mknittle's Avatar
Originally Posted by Denee007 View Post
Well, I'm thinking this option, possibly. I like the flip up lid to access the filler, but was wondering what do I put on the filler neck of the tank to keep gas from sloshing out? A cork? plus if I have to drop the gas tank, I don't have to mess around with disconnecting a hose from the bed. What do you think?
NW task, you might think about this option since you're using plywood.
I think a cork from a biiiigg wine bottle would work. but first you have to drink the wine
Mark
My GMC build.
http://67-72chevytrucks.com/vboard/s...d.php?t=536602
mknittle is offline   Reply With Quote
Old 04-26-2013, 11:52 AM   #35
Denee007
Denee007's Avatar
Omg, I was thinking just that however that'd be a large bottle
Old 04-26-2013, 11:54 AM   #36
mknittle
mknittle's Avatar
Dne'
hardware stores will have the hole saw s from 3/4" to 6" DIA. thesize you need will work on a 1/4" or 3/8" drill
Mark
My GMC build.
Old 04-26-2013, 11:56 AM   #37
mknittle
mknittle's Avatar
The biggest problem I see is recovery time
Mark
My GMC build.
Old 04-27-2013, 11:02 AM   #38
roger55
roger55's Avatar
I'm just beginning to think about a tank for my '57.
Here's some photos from a guy on the trifive.com site and it's really nice. I think I might go the same route as him.
This poly tank is from Tanks, Inc and it has an option for a fuel injection pump setup which I will need.
roger55 is offline   Reply With Quote
Old 04-28-2013, 05:34 PM   #39
roger55
roger55's Avatar
Well, I'm going to tag along with you on your thread~ you know I'll encounter the same problem when it comes time to install my bed! I just called Brothertrucks to see if they know anything, but they're not open yet.
dne'
It looks like the setup that I showed in my previous post is not going to work.
Would you do me a big favor and measure the height of that tank. Both in the rear where it's stepped down and in the front? I'm am having trouble finding those measurements anywhere online.
Also, I think I found that that rectangle dimensions at the bottom are 28" X 17 3/4". Is that correct?
I want to make sure it would fit my '57 " longbed ("89). The rearward crossmember in my truck is different than yours. I'd also like to see exactly how low this hangs down too.
I would sure appreciate the info.
Old 04-28-2013, 07:09 PM   #40
Denee007
Denee007's Avatar
Hey Roger! I don't have the measurements, but I can get them tomorrow~, but here are some pictures to give you an idea? Are you contemplating purchasing one of these tanks? Be sure to shop shop shop before you buy and explore all options
Old 04-28-2013, 07:29 PM   #41
roger55
roger55's Avatar
Thanks! I would definitely appreciate it. Your photos are helping too.
Yes, I've got it narrowed down to the one that you have and this one:
http://www.docskustom.com/shop/viewi...p?productid=61
It has a few disadvantages over yours in that it's smaller (15 gal) and more expensive. But, it's not going to hang down as low and it has a side-fill option. How much less it hangs down I can determine when you verify those measurements for me. Since this is going to be a daily driver and a work-truck for us, I like the side-fill idea.
Here's a photo I took yesterday of my frame. You can see that reward crossmember is different and it has the corner gussets.
Old 04-28-2013, 10:19 PM   #42
Denee007
Denee007's Avatar
Plus the overload spring stops are in the way. Will you be using these rear leaf springs? Brothers is always having sales. Don't buy until you're sure. Looks like you have time to think about it
http://www.brotherstrucks.com/prodin...number=SGT5559
Old 04-28-2013, 10:27 PM   #43
roger55
roger55's Avatar
Yes, I was planning on using them. We might very well be loading this truck up once in a while.
I looked at those spring stops and I think they would be pretty simple to modify so they're out of the way. I don't mind doing that but I really don't want to start messing with the crossmember.
Old 04-29-2013, 09:36 AM   #44
HiRMKin
HiRMKin's Avatar
I made my tank and my filler is just below the top of the wood. I will be using a gas door similar to the ones Denee007 is thinking about using.
HiRMKin is offline   Reply With Quote
Old 04-29-2013, 09:55 AM   #45
roger55
roger55's Avatar
Did you take out a crossmember to do that tank?
You can see in photo that I have a crossmember that would prevent me from using a tank like that without removing it.
Old 04-29-2013, 10:00 AM   #46
Denee007
Denee007's Avatar
Roger, I tried scanning the dimensions of the tank and sending them to the computer~ not going to happen; so
Follow me:
Top of the gas tank, running lengthwise of the truck: 11 7/8"
The step down or drop; goes down below the rear crossmember: 3 1/2"
The remainder of the back part of the tank that goes beneath the crossmember: 6"
The depth of the tank: 10 3/4"
The part you would see from behind the truck as the bumper would hide: 7 3/4"
I hope this helps and wasn't too confusing
dne'
Hirmkin, that's a nice looking tank! you made it?
Old 04-29-2013, 11:00 AM   #47
roger55
roger55's Avatar
dne'
Yes, that helps a lot. Thank you very much.
Just had a talk with my wife and we went out and looked at the truck. (This truck is hers so I make the presentations and she makes the decisions.)
I set a tape measure on the crossmember to show her how low each tank would hang down. (Yours hangs 1 3/4" lower than that Kustom's tank does.) Also, the bumper on our truck is narrow and doesn't cover it that well. So, she likes the idea of the Kustom tank better in that regard.
But, the kicker for her was the side fill option. She wants to be able to fill the tank if the bed is loaded with whatever since we are going to use it for hauling things. She didn't mind the idea of the smaller tank and having to fill a little more often either.
So, it looks like the Kustom tank is the one at this point.
Again, thanks for your help in making our decision.
Old 04-29-2013, 02:15 PM   #48
HiRMKin
HiRMKin's Avatar
Yes roger55 I did remove my rear cross member for two reasons. One I gained a few more gallons and it also brings the filler closer to the tailgate for easier filling.
Yes, Denee007 I manage a welding shop with a sheer and brake.
Old 04-29-2013, 02:23 PM   #49
roger55
roger55's Avatar
I could move my crossmember back about 7 inches and fit in the tank I was looking at earlier. This would save me over $200 over the Kustom aluminum tank I am looking at.
http://www.tanksinc.com/index.cfm/pa...prod/prd73.htm
I was figuring that the engineers who designed the frame put that crossmember right where the spring bracket mounts for stress and strain. Do you think it that might be a concern in moving it back?
Old 04-29-2013, 02:32 PM   #50
HiRMKin
HiRMKin's Avatar
They most likely did that by design. My truck will never haul anything heavy.
