Old 03-25-2013, 04:16 PM   #1101
85burb
85burb's Avatar
Re: 85 burb meets 6.0 lq4
That is what I told them to make it. I know it is not reading road speed. I talked to a local tuner and he said it most likely just needs a tune.
82 c10 5.3/4l60
84 c20 5.3/sm465
85 chevy k10 suburban LQ4/4l60
91 chevy c10 suburban Lsa 5.3/4l60
2017 Silverado whipple 5.3
1964 Vw beetle
1974 vw beetle
85burb is offline   Reply With Quote
Old 03-25-2013, 08:03 PM   #1102
85burb
85burb's Avatar
Talked to a place in Longview that does tuning. They sound like they know what they are doing. Good prices too. Should be able to go in a few weeks.
82 c10 5.3/4l60
84 c20 5.3/sm465
1964 Vw beetle
1974 vw beetle
Old 03-28-2013, 11:14 PM   #1103
85burb
85burb's Avatar
so i seen my ecm is not picking up my speed. I have a dakota digital pulse genorator and it is connected to my 2 wire vss pig tail. Am i not doing it correct?
82 c10 5.3/4l60
84 c20 5.3/sm465
1964 Vw beetle
1974 vw beetle
Old 03-29-2013, 12:31 AM   #1104
y5mgisi
Second Chance Program
y5mgisi's Avatar
I bet the pulse generator isnt the same out put as a stock VSS. Or else you have it wired backwards?
90 Chevy Suburban 2500 5.3 swap/th400/np241/14bltSF/10blt.
77 C20 crew cab Silverado. 396/th400. In work.
y5mgisi is offline   Reply With Quote
Old 03-31-2013, 04:15 PM   #1105
85burb
85burb's Avatar
I have wired it both ways. I think it is working better this way. Says 4 mph at 65 mph.
I got my check engine light installed and working today. Only have one code now. I had a code for knock sensor 2 bank 2 low voltage. Found my wires were pulled to tight. Rerouted wire and test drove a few times. No more codes other then crank relearn code.
82 c10 5.3/4l60
84 c20 5.3/sm465
1964 Vw beetle
1974 vw beetle
Old 03-31-2013, 06:20 PM   #1106
watahyahknow
watahyahknow's Avatar
maibe the sensor doesnt pick up all the pulses maibe you need to get it closer to the eeeh thoothed wheel that gives the signal
i got a job again and having fun at it too
idea's for the trucks and the order of things to do are taking shape and get closer to being realized , a few more months and i be able to start building for real
i complete 2 of the trucks intoo running fashion one custom and one basicly stock the thirth will be sacrificed for parts
watahyahknow is offline   Reply With Quote
Old 04-15-2013, 06:37 PM   #1107
85burb
85burb's Avatar
Woohoo. Got a hold of a snap on solus scanner and ran the crank learn thing. Boy that is a fun test. You have to rev up tell fuel cut out it says. Well first try I bounced it off of rev limiter for a few seconds. Then the second time it went to 4000 then cut out and went to limiter again. And passed. So no more check engine light.
82 c10 5.3/4l60
84 c20 5.3/sm465
1964 Vw beetle
1974 vw beetle
Old 04-15-2013, 07:10 PM   #1108
watahyahknow
whell its fixed thats wat counts , bet youre neighbours where happy hearing the engine go crackle and pop
Old 04-15-2013, 07:15 PM   #1109
85burb
85burb's Avatar
I don't worrie about them. They don't worrie about us. They all let there dogs run wild. We live out in the country so there is some room in between us. The people on the corner are the ones that probably don't like me when I take off out of my street.
82 c10 5.3/4l60
84 c20 5.3/sm465
1964 Vw beetle
1974 vw beetle
Old 04-24-2013, 08:46 PM   #1110
85burb
85burb's Avatar
Small update. I finally got my throttle cable bracket. I have also set up a street/dyno tune for monday. I cant wait to see what the differance will be. I would also like to know what kinda power i have.
82 c10 5.3/4l60
84 c20 5.3/sm465
1964 Vw beetle
1974 vw beetle
Old 04-24-2013, 09:47 PM   #1111
MalibuSSwagon
If you have a stock VSS on your transmission, just run the 2 wires straight to the ECM's VSS High and VSS Low pins. Your tuner will be able to program the tire size and VSS pulse per rev into the ECM. The ECM should be reading the speed correctly at that point, and will also have a 4K PPM output for your speedometer, and cruise control if equipped.
MalibuSSwagon is offline   Reply With Quote
Old 04-24-2013, 09:50 PM   #1112
85burb
85burb's Avatar
I do not have a vss in my 700r4. It is the old style. I wish it did.
82 c10 5.3/4l60
84 c20 5.3/sm465
1964 Vw beetle
1974 vw beetle
Old 04-26-2013, 01:55 PM   #1113
MalibuSSwagon
Does your tailhousing have a speedo cable drive opening like this?
If it does you can swap out the cable drive housing for one of these:
Its a VSS/cable drive for a 1991 - 1993 Caprice 9C1, GM made and installed them so the cops could use cable driven radar units on the TBI cruisers.
You can still get them as Standard Motor part # SC55, or AC Delco 213201. Its a 40 pulse output.
There is also an inline 40 pulse VSS available from Jags that Run. You would need #3.
All of these options do not require the Dakota Digital box.
Old 04-26-2013, 01:58 PM   #1114
85burb
85burb's Avatar
No it is 4wd
82 c10 5.3/4l60
84 c20 5.3/sm465
1964 Vw beetle
1974 vw beetle
Old 04-26-2013, 02:32 PM   #1115
watahyahknow
doesnt it still be on the connection part of the trans to the the transferbox?
i've seen sumtin else a while back they use them on kitcars mostly its a metal plate with fins that fit between the knucklejoint and the rear diff and theres a small bracket that holds a hall sensor close to it , works verry accurately once its calibrated
cant find that perticulair one but found this one
if they made abs for youre model you might want to try to fit one of those sensors they basicly do the same thing but are made to fit youre car/truck of the shelf and are eazier to get replacement parts for
Old 04-26-2013, 02:40 PM   #1116
85burb
85burb's Avatar
I am taking it to be tuned tomorrow so of he can make it not stall I will not worry about it
82 c10 5.3/4l60
84 c20 5.3/sm465
1964 Vw beetle
1974 vw beetle
Old 04-26-2013, 05:20 PM   #1117
y5mgisi
y5mgisi's Avatar
Im sure he can! I dont run the speed sensor on mine and it has never stalled.
Old 04-26-2013, 05:40 PM   #1118
85burb
85burb's Avatar
Good to hear!
82 c10 5.3/4l60
84 c20 5.3/sm465
1964 Vw beetle
1974 vw beetle
Old 04-26-2013, 05:55 PM   #1119
83GMCK2500
Forgive me if this was covered, there are a lot of pages...
Couldn't you use a 90/91 NP241 transfer case from a Suburban/K5 that has an electronic VSS?
Devin
1983 GMC High Sierra 2500, 4x4, RC/LB, 400 S.B., SM-465, NP-208, Corporate 10 bolt & 9.5" 14 bolt
1996 GMC Sierra SLE 3500 DRW, 4x4, EC/LB, Vortec 454, NV-4500, BW-4401, AAM 925 & AAM 1050
1997 GMC Sierra SLT 1500 4x4, Z71/F44, EC/SB, Vortec 350
My Introduction with my '83s History
New Daily, the '96
83GMCK2500 is offline   Reply With Quote
Old 04-26-2013, 07:05 PM   #1120
y5mgisi
y5mgisi's Avatar
You can but then you have to do something about the speedometer. A cable-x converter or switch to a 90-91 burb/blazer speedo/drac.
Old 04-26-2013, 09:52 PM   #1121
85burb
85burb's Avatar
I will have to looking to the 241 if my tuner cant get it strait. Thanks for bring that up i had forgot
82 c10 5.3/4l60
84 c20 5.3/sm465
1964 Vw beetle
1974 vw beetle
Old 04-27-2013, 09:29 PM   #1122
85burb
85burb's Avatar
Well the truck is at te tuners place. He was a hour and a half late so not real happy so far.
82 c10 5.3/4l60
84 c20 5.3/sm465
1964 Vw beetle
1974 vw beetle
Old 04-29-2013, 08:38 PM   #1123
y5mgisi
y5mgisi's Avatar
Ouch... Good luck man! Really hope he gets it where you want it!
Old 04-29-2013, 08:39 PM   #1124
85burb
85burb's Avatar
We will see. I am going to get it now.
82 c10 5.3/4l60
84 c20 5.3/sm465
1964 Vw beetle
1974 vw beetle
Old 04-29-2013, 08:42 PM   #1125
y5mgisi
y5mgisi's Avatar
Fingers crossed!
