Originally Posted by Xeen
My advice is not wrong you need to be able to bolt everything together before you can say things don't fit, untill you can bolt the trailing arms to the axle and instal the trac-bar you won't know anything.
Also the trailing arm attachment point is a guideline not a rule, the angle your trailing arms end up when the truck is laid out is impacted by the starting position of the trailing arms.
You will probably have to move your crossmember to get the trailing arms to be in the right position when the truck is laid out.
Gotcha xeen thanks allot man I appreciate your advice
![Smilie](http://67-72chevytrucks.com/vboard/images/smilies/smile.gif)
Ill keep you guys posted on my build
