Old 04-25-2013, 08:40 PM   #1
CamberC10
CamberC10's Avatar
High hump?
What is the high hump for ?
CamberC10 is offline   Reply With Quote
Old 04-25-2013, 09:03 PM   #2
wgr2112
Re: High hump?
High humps are usually found on 4x4s and big block/turbo 400 2wds, but not always!
If you have no carpet, or it is removed, there is a removable, bolt in cover on the high humps.
Clear as mud?
wgr2112 is offline   Reply With Quote
Old 04-25-2013, 09:33 PM   #3
71swb4x4
71swb4x4's Avatar
Re: High hump?
High humps came on 4x4's and 4-speed manual trucks. I believe on the big block TH400 trucks too, usually. Some boardmembers have the TH400 with a low hump.
The low hump is part of the floor pan, the high hump is bolted in. You can easily cut the low hump out and bolt a high hump in.
Some people are like slinkies, they aren't good for anything, but you can't help but smile when you see one tumble down the stairs.
71swb4x4 is offline   Reply With Quote
Old 04-25-2013, 09:36 PM   #4
wgr2112
Re: High hump?
My 72 1/2 ton 2wd 400/TH400 has a high hump.
Picture attached.
Old 04-26-2013, 06:36 AM   #5
bobs409
1969 Custom 30 wrecker
bobs409's Avatar
Re: High hump?
Don't forget trucks with the 4 speed. (probably the main reason they had high humps!) Both my Cheyenne 20 and Custom 30 have it.
Bob
63 Impala 283/PG/3.36 (under restoration)
66 Impala 327/PG/3.36
66 Chevelle SS 409/M22/3.55
69 Chevelle 307/PG/3.08 (future restoration)
69 C10 short stepside 454/TH350/3.73
69 Custom 30 tow truck 350/4 spd/4.10 (resto done, CRUISIN TIME!)
71 Cheyenne 20 fleetside 350/4 spd/4.10
71 Chevelle 6/PG/3.08
72 Chevelle 454/M21/4.10
bobs409 is offline   Reply With Quote
Old 04-26-2013, 09:37 AM   #6
Stu Pidd
Re: High hump?
When looking at trucks, I only considered high-hump trucks so there is plenty of room for the Tremec 5-speed tranny that will reside there before long.
Stu Pidd is offline   Reply With Quote
Old 04-26-2013, 09:47 AM   #7
dan42
dan42's Avatar
Re: High hump?
Be aware that there are two types of covers - a 6 cylinder, and an 8 cylinder. The placement of the opening for the shifter is a little different (in the manual trucks). I'm not sure if the high hump in the autos had any opening on them at all.
'67 SWB Fleetside ZZ4/350/Tremec 5-speed/4link/Scott's IFS - and fun as heck! SOLD
Click here to support the board
Philippians 4: 6-7
dan42 is offline   Reply With Quote
Old 04-26-2013, 10:16 AM   #8
LDO
LDO's Avatar
Re: High hump?
Dan,
Any pics of the differences? My 66 has a low hump but I noticed that the shifter hole isn't actually centered...
LDO is online now   Reply With Quote
Old 04-26-2013, 02:53 PM   #9
wgr2112
Re: High hump?
There are no cutouts or openings in the auto trans covers.
Old 04-26-2013, 03:54 PM   #10
SS Tim
SS Tim's Avatar
Re: High hump?
Autos have no holes other than mounting which makes them useful for trans swaps.
The 4-speed V-8 shifter hole is up forward and pretty much at the upward flaired section the I-6 location is 3.8" further back and conpletely on the flat section. There are illustrations in the assembly manual if you dig around.
SS Tim is offline   Reply With Quote
Old 04-26-2013, 04:24 PM   #11
StepinNJ
TuTone Silverado
StepinNJ's Avatar
Re: High hump?
I think this is for a V8 4X4. Got it as a spare part with the truck I bought.
13 Corvette GS vert
13 Ram Laramie Longhorn
11 Wrangler Sahara unlimited
08 300
76 El Camino
67 Bel Air sedan
63 Corvette SWC
08 HD Road King Classic
68 HD Golf car
StepinNJ is offline   Reply With Quote
Old 04-26-2013, 04:53 PM   #12
SS Tim
SS Tim's Avatar
Re: High hump?
Pretty sure that is a V-8 4x2 4-speed cover. The V-8 4x4 is aft the same as the I-6. My mistake earlier.
Old 04-26-2013, 05:25 PM   #13
SS Tim
SS Tim's Avatar
Re: High hump?
This might help. Also shows the double bend vs single bend levers.
Old 04-26-2013, 06:30 PM   #14
Mister-B
Re: High hump?
Here's a pic of mine. TH400 2WD. Is it high or low hump?
Mister-B is offline   Reply With Quote
Old 04-27-2013, 08:45 AM   #15
wgr2112
Re: High hump?
it LOOKS like a high hump to me.
Old 04-27-2013, 01:23 PM   #16
SS Tim
SS Tim's Avatar
Re: High hump?
Low
Old 04-28-2013, 11:13 AM   #17
wgr2112
Re: High hump?
Based on those pics, I change my vote to low hump.
