04-27-2013, 04:21 AM | #1 |
6 lug? 5 lug? or both?
So I have a 55' 3100 with a TCI Must II front clip and what I believe is a 10 bolt truck rear end. My question is what would the most economical solution as far as which bolt pattern to run. The fronts are 5 X 4 3/4" and the rear is 6 lug. The short term solution is to run both with a rally wheel that has caps to hide the mismatched bolt pattern. In the long run, I'd like to get a set of 5 or 6 spoke wheels. the options so far are..
- remove the axles and have them drilled out to 5 X 4 3/4" - buy the TCI 6 lug disc conversion. The problem with the first option is the cost and time may outweigh buying a new (wrecking yard) rearend. The second option would be nice except, the only part I need from the kit is the 6 lug rotors. So, when i eventually have to replace the rotors, I would assume I'd have to re buy the kit just replace the rotors. Does anyone know of a company that makes 6 lug rotors that will fit? I've looked at CCP and TCI and they come as a kit. The other option may to be replace the axles with 5 lug. Any help would be greatly appreciated.
55' 3100 big window |
04-27-2013, 09:18 AM | #2 |
Re: 6 lug? 5 lug? or both?
Just have the rear axles drilled to 5 lug any machine shop can do it and cheaper than buying six lug conversion, plus more options on wheels on 4 3/4 pattern. I was going to go with six lug at first but if you use stock wheels than depending on rims you have to use tubes.
http://67-72chevytrucks.com/vboard/s...d.php?t=436442 |
04-28-2013, 05:33 PM | #3 |
Drill the rear axles to match front.
04-28-2013, 10:58 PM | #4 |
Thanks for the input.
