Old 04-28-2013, 09:37 AM   #1
Rubble
Removing tree sap off the hood & roof
The latest truck I got was parked under trees & sap dripped onto it. I have tried dish soap & then citrol but not much luck.The black sap really shows up on a white truck! Any ideas??? Thanx.
1977 Chev C30 454/465/14ff DRW
1974 Chev C20.350/465/14ff
" Rock n Roll ain't noise pollution"
Rubble is offline   Reply With Quote
Old 04-28-2013, 10:16 AM   #2
GM-power
GM-power's Avatar
Re: Removing tree sap off the hood & roof
Use peanut butter. Put a little on your fingers, rub it for a bit and then let it sit for awhile. That should get it off.
1979 Sierra Classic Heavy-half
1996 Silverado x-cab "the daily"
GM-power is offline   Reply With Quote
Old 04-28-2013, 10:43 AM   #3
LONGHAIR
I would start with mineral spirits. This will get most of it pretty quickly. Then follow up with a clay bar. That will get all of what's left. If you only had a little bit, the clay bar would do it, but you would ruin it with too much contamination.
You can review the site's rules here.
Originally Posted by Longhorn Man View Post
As for reading directions...
The directions are nothing but another man's opinion.
Learn from the mistakes of others, you won't live long enough to make them all yourself...
Bad planning on your part does not necessarily constitute an instant emergency on my part....
The great thing about being a pessimist is that you are either pleasantly surprised or right.
LONGHAIR is offline   Reply With Quote
Old 04-28-2013, 11:25 AM   #4
dieseldawg142
dieseldawg142's Avatar
being in the roofing industry, we get tar & different kinds of bitumen all over our trucks, same sticky consistency of sap. if you go to a roofing supplier, you can get "Trim S", made to take tar off ANYTHING, & leaves no stains. i have used this stuff to take tar out of carpet with no staining. have also used good 'ol WD40 without any damage to paint eitherName:  456.jpg
dieseldawg142 is offline   Reply With Quote
Old 04-28-2013, 11:35 AM   #5
Rubble
Thanks for all the suggestions,going out to shop in a bit and try them.Will post results later.
Old 04-28-2013, 03:04 PM   #6
mrolds88
Several suggestions. Dawn dish soap and soft but stiff sponge and if you have Dollar Tree stores up there they sell a cleaner called Awesome. Comes in squirt bottle and works well for everything I have tried to remove. Had a Camaro one time, was white and had been parked under a maple tree for a long time. Cleaned up real well with the Dawn. Only bad part it was February and snowing outside. That was cold!!
72 GMC C2500 402/Th400 first truck (still have)
77 GMC C3500 CC dually Sold
70 C50 dump truck "Rusty"
87 K10 Suburban Sold
93 K2500 xcab 6.5TD
96 GMC K2500 Suburban 6.5 TD
mrolds88 is offline   Reply With Quote
Old 04-28-2013, 11:08 PM   #7
speedmachine
wd40 x2
speedmachine is offline   Reply With Quote
Old 04-28-2013, 11:17 PM   #8
MalibuSSwagon
Rubbing alcohol, it will soften the sap right off
MalibuSSwagon is offline   Reply With Quote
Old 04-28-2013, 11:21 PM   #9
weaintscared
weaintscared's Avatar
WD-40 is all I use,,works on that & removes tar too.
weaintscared is offline   Reply With Quote
Old 04-29-2013, 12:20 AM   #10
PAWS 72
PAWS 72's Avatar
Originally Posted by speedmachine View Post
wd40 x2
Now I find out.
PAWS 72 is offline   Reply With Quote
Old 04-29-2013, 12:42 AM   #11
Rubble
Tried WD40,peanut butter,solvent,citrol but not any luck.I forgot to say in my first post too,this truck sat in the trees for about 7-8 years so it's had a long time to soak in...Will try a few more of the ideas here,thank again
Old 04-29-2013, 07:22 AM   #12
bigd65
bigd65's Avatar
Try Maguires CLEANER WAX !!!!
2004 Silverado Crewcab
1972 Chevy Monte Carlo
2017 Chevy Tahoe
bigd65 is offline   Reply With Quote
Old 04-29-2013, 09:20 AM   #13
bilfman
bilfman's Avatar
I assume you are meaning the dryish black tree staining. If it is old you may have to use a buffer and a light rubbing compound, followed by a polish.
1979 Chevy Dually Crew 4X4 454, D60 Tru-trac, D70 Detroit Locker, 3.73, 4L80E/NP205
1971 GMC 3/4 Ton 4X4
bilfman is offline   Reply With Quote
Old 04-29-2013, 10:03 AM   #14
ont_guy_38
ont_guy_38's Avatar
White truck...Black sap...7-8 years, Bifman has the right idea, but even then, it might possibly not all come out.
1985 C10
2004 Avalanche
ont_guy_38 is offline   Reply With Quote
Old 04-29-2013, 10:20 AM   #15
Rubble
Ya,sorry guys.I wasn't clear enough.Yes it's the dry black sap,not fresh green stuff.On a white truck,it really shows up eh....
Old 04-29-2013, 11:49 AM   #16
rs72z
rs72z's Avatar
Single edge razor blade and be very careful. Only use one side of the blade and if you drop it chunk it.
___________________
78 ccsb dually
5.3
4l60e
http://67-72chevytrucks.com/vboard/s...d.php?t=491551
rs72z is offline   Reply With Quote
Old 04-29-2013, 06:29 PM   #17
Hertzdaddy
X2. I used a 50/50 mix with water. You may need full strength. Wax afterwards.
Edit: Actually it was denatured alcohol like you get at the hardware store.
Hertzdaddy is offline   Reply With Quote
Old 04-30-2013, 01:25 AM   #18
PAWS 72
PAWS 72's Avatar
Try clorox. It helped with mine but it's red.
Old 04-30-2013, 05:48 PM   #19
HTX86chevy
HTX86chevy's Avatar
Walmart sell some stuff called "GOO-gone". you can find it where the sell the mops and brooms and other cleaners. this stuff works pretty good.
good luck buddy.
HTX86chevy is offline   Reply With Quote
Old 05-04-2013, 09:43 AM   #20
1LowToy
I used some maguires and rubbing alcohol and it took it off of my buick. Another wierd one is orange hand cleaner. I accidently dripped some on a guys old blue truck. wiped it off and it shined like new penny
1LowToy is offline   Reply With Quote
Old 05-04-2013, 02:26 PM   #21
Rubble
Will try some more of your suggestions,thanx again eh.....
Old 05-05-2013, 04:01 AM   #22
76C10Stepside
76C10Stepside's Avatar
Goop hand cleaner works great for most glues and such. My son just removed chewing gum from a car with it today, worked great. Regular old vegetable oil is another one (it's the oil in peanut butter that does the work). Let the oil soak in overnight. Since the sap is so old, it has dried out and hardened. Vegetable oil is the cheapest and won't harm the paint.
76C10Stepside is offline   Reply With Quote
Old 05-05-2013, 11:01 AM   #23
1774btcrew
1774btcrew's Avatar
I would strongly suggest AGAINST using a razor blade. I am a pefectionist and it is still easy to nick the paint. You can get a plastic razor blade and most automotive paint stores or use a plastic putty knife if you want to try and scrape it off. NEVER use something metal to scrape on a painted surface you want to preserve. I would use the Trim S like dieseldawg suggested. If anyone should know about removing tar it is a roofer!
AZPartsLocators on Instagram
1972 Cheyenne Super Short Bed big block "Blackie"
1977 Crew Cab GMC Short bed with 4BT Intercooled Cummins Diesel and a 4L80e "The Junkyard Dog"
1985 Crew Cab Chevy dually with 5.9 Cummins "The Big Dog" This is what my dad liked to be called by the grandkids before he passed so it seems fitting for his old truck.
1774btcrew is offline   Reply With Quote
Old 05-05-2013, 11:58 AM   #24
Raised On Chevy!
Raised On Chevy!'s Avatar
I own an Auto Body shop and we also do auto detailing, all we have ever used is gas line antifreeze. It softens it but I'm not sure about something that old.
Raised On Chevy! is offline   Reply With Quote
Old 05-05-2013, 12:15 PM   #25
Rubble
Ya,I guess in his defense,I didn't clarify that the sap was the black stuff & was 6-8 years old too.And yes they should know about removing tar eh!!
