Old 04-28-2013, 07:36 PM   #1
sam059
Big block, small block
Hello, new to thew forum. I am fortunate and actually have a choice, would like some thoughts. I have a 1967 C10 Arizona truck that i am going to restore, frame up. I have a 1971 350 V8 with a turbo 350 transmission, this is my choice. I also have a 1986 454 V8 with a turbo 400, newly rebuilt. I am going to build the small block and use that, truck will be a driver not a sitter. But which transmission? I will use truck to tow boats and medium size trailers. I am thinking turbo 350, 400 is heavier. Anyway, any thoughts?
sam059 is offline   Reply With Quote
Old 04-28-2013, 07:48 PM   #2
vidman
vidman's Avatar
Re: Big block, small block
I would use the 400 in place of the 350. will last longer when towing... or you could just drop in the 454-400 and all your problems would be solved
62 Willys 4wd Pickup : 72 C-10 swb 504 stroker 09 Taco 3" lift 33" tires: 90 K-5 blazer (plow truck): RIP Ross Little brother
vidman is offline   Reply With Quote
Old 04-28-2013, 09:25 PM   #3
1972RedNeck
1972RedNeck's Avatar
Definitely the turbo 400. I built up a small block one time. Dad's bone stock 454 vortec would way out pull my sbc. They both got horrible fuel mileage when towing.
1966 F250 4X4 416
1972 K20 350 4 OTF
Originally Posted by GASoline71 View Post
I once pulled an intake manifold for a cam swap... ended up with a full on drag car that ran in the 11's.
1972RedNeck is offline   Reply With Quote
Old 04-28-2013, 09:31 PM   #4
snj8198
snj8198's Avatar
yep, they both get poor mileage when working so you might as well have the power. Go big block and turbo 400. However, i would change the 400's first gear from the anemic 2.48-1 ratio to the deeper 2.75. It really helps the truck off the line under load.
Steve
1971 GMC Longbox. Full Roller Stroker 489 w/ FiTech EFI, Chris Straub Cam/NV4500/205/D60/14B w. Grizzly Locker and 4.11's. 2" Lift on 33's
snj8198 is offline   Reply With Quote
Old 04-29-2013, 01:02 AM   #5
70cst
70cst's Avatar
Hey sam059 ...
Just wanted to say to the forums and from Ohio.
A husband can be right...or...A husband can be happy.
67-72 Chevy and GMC Trucks...The Classic Truck for the Classic Folk.
1970 CST Two tone green, 402BB, 400 Automatic, Tach, Buckets, AC, AM-FM, Tilt, GM CB, GM 8 Tract, LWB, etc
JOHN 17:3...The better side of "LIFE"
Remember: Everyday is a good day...Some are just gooder!
70cst is offline   Reply With Quote
Old 04-29-2013, 08:29 AM   #6
MARKDTN
350 and TH400 trans
'83 K20-TPI
'73 C10
'79 C10-ex-diesel(SOLD)
'07 Tahoe(Son driving)
'14 Suburban-DD
'71 C10-current project
MARKDTN is offline   Reply With Quote
Old 04-30-2013, 12:17 AM   #7
67ctener
67ctener's Avatar
Go big block if you have it
Scott
67 c10 sold
89 c1500
90 k2500
91 s10
#chevyonly
67ctener is offline   Reply With Quote
Old 04-30-2013, 12:21 AM   #8
leddzepp
Moderator
leddzepp's Avatar
Th400
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed.
1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck.
RIP ElJay
RIP 67ChevyRedneck
RIP Grumpy Old Man
RIP FleetsidePaul
