shocks for a bagged truck
What kind of shocks should I run when I bag my truck? I was looking at the belltech nitro sport truck drop shocks 2 or whatever for the front and rear, but im assuming I should just by the ones that are suggested for the biggest drop right? Or is there a way i should measure my set up to figure out what kind to get?
1980 C10 SWB Yukon 5.3/5 speed 3.73 gears. |
Square
Re: shocks for a bagged truck
your shock needs to have as much travel as your bags. I like the Toxic shocks, they are cheap and proven.
Squarebody Syndicate |
low n' slo
![]() Join Date: Mar 2009
Depends on how low ur going too...
I used 1950 chrysler imperial shocks. Extended/collapsed height worked perfect and both sides have the "eye" style ends to run a bolt through like stock shocks Posted via Mobile Device
67 1/2 ton Suburban - Project DRGNWGN. Build thread ![]() -_--_--_ _________ _--_-_ -/____|__|__\__ ,.,,,.,.,,.,|_O _______ O_] |
I would suggest shock extenders when bagging. If you keep the stock location, you need a really short shock to be able to collapse all the way when aired out. This will limit your up travel as well. A drop shock will not collapse all the way if you are bagging a truck using this stock upper shock location.
Best way is to get a relocation bracket, such as a Porterbuilt. ![]() ![]() |
#5 | |
#6 | |
Posted via Mobile Device |
The part# C10SRB
Is there someone that makes one of those but has a stud on it so you can use the stock eye/eye shock?..
-'73 c/10 - Low with Go - will be complete... probably never. -'90 2wd Blazer - well... soon enough anyways. -'84 SWB - the daily gas guzzler. |
Yes, they make one, but it is taller because it is used for the Dropmember trucks.
Yeah those are tall.. probabky just end up makong my own.. lol
For something on the cheap, these are the factory 73-87 mounts cut off the rear end housing used with 1980s Jeep CJ5 rear shocks on the front of an 85 C10.
