Old 05-02-2013, 10:16 PM   #26
85supersierra
85supersierra's Avatar
Re: differential question
this is the g-80 gov lock Name:  101_1826.jpg
im surprised my 8.1 hasnt blown it out yet but it does not work all that well and i plan to replace it
85supersierra is offline   Reply With Quote
Old 05-02-2013, 10:18 PM   #27
85supersierra
little better picName:  101_1818.jpg
Old 05-02-2013, 10:46 PM   #28
85supersierra
anyone ever use an auburn or yukon gear unit from summit
Old 05-02-2013, 11:45 PM   #29
i heart square bodys
i heart square bodys's Avatar
Is it possible to remove said grenade lock and replace it with something better? what woulf be suggested to use as a posi?
1986 LWB c10 w/327 & vortec heads
i heart square bodys is offline   Reply With Quote
Old 05-03-2013, 05:28 AM   #30
b454rat
Anything other than that pic...
2000 Chevy Tahoe Limited 3/5" drop
2000 GMC CCSB 454/4L80 6” lift SAS
1999 Chevy CCSB 454/NV4500 4” SAS
1999 GMC Yukon stock SAS 6"
Old 05-03-2013, 06:30 AM   #31
bigd65
bigd65's Avatar
Poncho, where is SHARYLAND TX
2024 Silverado Z71 PPV
1972 Chevy Monte Carlo
2018 Buick Enclave (Wifes)
bigd65 is offline   Reply With Quote
Old 05-03-2013, 07:41 AM   #32
Rich84
Rich84's Avatar
I got an Auburn out of an 89 Suburban for $80.00 in like new condition..Functions well, but they are not rebuildable. I think it will probably last forever in a cruiser. I got lucky at the junkyard, someone had removed the cover but was not able to get the carrier out...Easy Pickens..
Rich84 is offline   Reply With Quote
Old 05-03-2013, 08:44 AM   #33
PONCHO130
PONCHO130's Avatar
Originally Posted by ont_guy_38 View Post
Check to see if it's a posi, if it is check the width of the complete rear end and mounting perches. I think they might be the same width as your 81. Switch the whole rear end and your all set.
how would i be able to find out if its a posi?
PONCHO130 is offline   Reply With Quote
Old 05-03-2013, 08:45 AM   #34
PONCHO130
PONCHO130's Avatar
south texas between mcallen and mission
Old 05-03-2013, 09:28 AM   #35
motornut
78K & 79C Jimmys
motornut's Avatar
Originally Posted by i heart square bodys View Post
did the 12 bolts fall into the gov-lock thing ? or just the 10's? ive found a 12 bolt with 5x5 lug axles that a buddy has but im not paying for it if its a waste in the long run.
my 79 4X2 is 12 bolt G80@3.4
and i think my 78 14 bolt 4X4 says a g80 too?
wondering that too, i wana "pull the pin,before it falls out" lol
John
1978 GMCJimmy4X4-350/203
1979 GMCJimmy4X2-305/350
Old 05-03-2013, 09:34 AM   #36
ont_guy_38
ont_guy_38's Avatar
The safest way is to take the cover off and have a look.
1985 C10
2004 Avalanche
ont_guy_38 is offline   Reply With Quote
Old 05-03-2013, 09:51 AM   #37
PONCHO130
PONCHO130's Avatar
should it look like the pic posted by 85supersierra
Old 05-03-2013, 10:07 AM   #38
ont_guy_38
ont_guy_38's Avatar
Being a 89, yes probably, just keep in mind that this is not the good one, but for free I guess you can't go wrong. Just take the cover off and post a picture as if someone has added an aftermarket posi it could look totally different.
1985 C10
2004 Avalanche
Old 05-03-2013, 01:29 PM   #39
PONCHO130
PONCHO130's Avatar
its a stock one off the burban didnt know bout codes at the time i took it cause someone told me burban rear ends come with 3.73 gears
Old 05-03-2013, 01:41 PM   #40
ont_guy_38
ont_guy_38's Avatar
That is very possible that it has 3:73 gears in it, but unless you know the complete history of that vehicle you have no idea what is actually in that pot. My rear end was a single track with 2:73 gears, now it is an eaton posi with 4:10 gears. What I'm saying is we could guess all day long but until you take that cover off nobody will know for sure. Chances are you are going to change the oil anyways if you use the whole rear end.
1985 C10
2004 Avalanche
Old 05-03-2013, 02:13 PM   #41
PONCHO130
PONCHO130's Avatar
you are so right, ill be doing that this weekend and ill post some pics. thanx!
Old 05-03-2013, 02:14 PM   #42
PONCHO130
PONCHO130's Avatar
Old 05-03-2013, 02:53 PM   #43
Is it possible to remove said grenade lock and replace it with something better? what would be suggested to use as a posi?
anyone???
Old 05-03-2013, 03:13 PM   #44
ont_guy_38
ont_guy_38's Avatar
anyone???
Yes you can remove it and replace it with a clutch type posi.
1985 C10
2004 Avalanche
